| i have made up a circuit with an optic sensor, LM555 timer and transistor. i am getting a pulse, but the transistor is staying on can some one help please Last edited by jasonspinmaster; 6th June 2008 at 10:39 PM. | |
| Does the transistor go off when you remove the light source from the phototransistor? | |
| ron. i get a pulse , but the transistor is on at the same time. so i have an electro magnetic field with another pulse on top | |
| the transistor should switch ON when the light is blocked. i am using a nail which is 1mm wide the slot is 0.75mm wide Last edited by jasonspinmaster; 8th February 2008 at 06:43 PM. | |
| the transistor should switch ON when the light is blocked. i am using a nail which is 1mm wide the slot is 0.75mm wide | |
| Your circuit is a not a pulse generator. If all your parts are good, the transistor will turn on when the voltage on pin 2 is below Vcc/3, and it will be off when the voltage is above Vcc/3. You could have other design errors. 1. You don't show a power supply. What is the voltage (Vcc)? 2. What is the resistance of your load (the coil)? | |
| 12 volt motor bike battery coil resistance 10 ohms | |
| You should be driving the base of the 2N3055 with at least 120mA (Ic/10). This means the base resistor should be about 75 ohms, unless you are using a CMOS 555, which can't source 120mA, so you would need to switch to a bipolar 555 before proceeding. You also need some capacitors from Vcc to ground, with short leads, as close to pins 1 and 8 as possible. I would use a 100nF (0.1uF) ceramic cap in parallel with an electrolytic, 100uF or so. If you want to create a fixed length pulse, you need an RC timing network. Where did you get this schematic? | |
| my timer is a LM555, it is the right one????? i got the schematic from some one on this web page. could you be kind enough as to send me some circits that works as the last 6 months have been hell. i only need the pulse to fire inconjuction with the nail (trigger)blocking the light Last edited by jasonspinmaster; 9th February 2008 at 01:53 AM. | |
Do you have a lot of ambient light? That will make it more complicated. | ||
| There is a duplicate or triplicate thread about this circuit. I corrected it by changing the 2N3055 for an MJ2955 and moving the coil to ground. But he says his MJ2955 keeps on blowing up.
