| Experienced Member | I layed out the pc board with the power supply traces first(12v+, 12v-, grd) have 2 or three jumpers on the ground traces(all the supply traces are .030 wide on 2oz boards. have lots of jumpers for the small signal stuff (.010) am thinking I should add some .01 caps around the board but this is a simple graphic equlizer not digital. Should I still run the caps and use tatinum .01uf? got to be a better way instead of a DS board? will post pic of proposed layout when I get closer to final layout |
| Experienced Member | You can't get tantalum 0.01 F capacitors.I normally use 100nF (0.1 F) ceramic capacitors across the power supply pins of each IC and near transistors that switch large loads. |
| Experienced Member | being and audio circuit (eqlizer) circuit which does no fast switching except in the display circuitry I probally don't need the caps but just for making the supply cleaner I just might throw them in. still trying to sifer the data sheets to figure the current draw of entire circuit for power supply |
| Super Moderator | Quote:
| Experienced Member | Quote:
__________________ RadioRon | |
| Lots of op-amps. Need ideas on what to do with em. | pkshima | Electronic Projects Design/Ideas/Reviews | 10 | 4th May 2005 12:21 PM |
| is reading lots of schematics the best way to learn? | psasidisrcum | General Electronics Chat | 17 | 18th April 2005 08:57 PM |
| Jumpers! | 2camjohn | General Electronics Chat | 2 | 16th June 2004 09:43 PM |
| Require help on jumpers | sename | Electronic Projects Design/Ideas/Reviews | 1 | 20th January 2004 12:06 PM |
| Ics and Jumpers | Cyclone | General Electronics Chat | 5 | 3rd October 2003 03:30 PM |
