Old 8th February 2008, 11:29 AM   (permalink)
Experienced Member
MrDEB can only hope to improve
Default Lots of jumpers??
I layed out the pc board with the power supply traces first(12v+, 12v-, grd)
have 2 or three jumpers on the ground traces(all the supply traces are .030 wide on 2oz boards.
have lots of jumpers for the small signal stuff (.010)
am thinking I should add some .01 caps around the board but this is a simple graphic equlizer not digital. Should I still run the caps and use tatinum .01uf?
got to be a better way instead of a DS board?
will post pic of proposed layout when I get closer to final layout
MrDEB is offline   Reply With Quote
Old 9th February 2008, 10:30 AM   (permalink)
Experienced Member
You can't get tantalum 0.01µF capacitors.
I normally use 100nF (0.1µF) ceramic capacitors across the power supply pins of each IC and near transistors that switch large loads.
Hero999 is online now   Reply With Quote
Old 9th February 2008, 12:57 PM   (permalink)
Experienced Member
being and audio circuit (eqlizer) circuit which does no fast switching except in the display circuitry I probally don't need the caps but just for making the supply cleaner I just might throw them in.
still trying to sifer the data sheets to figure the current draw of entire circuit for power supply
Old 9th February 2008, 01:24 PM   (permalink)
Super Moderator
You NEED supply decoupling capacitors, you should ALWAYS fit them - it's a very important part of every circuit.
Old 9th February 2008, 07:52 PM   (permalink)
Experienced Member
RadioRon is just really niceRadioRon is just really niceRadioRon is just really niceRadioRon is just really nice
I agree with this. Without on-board decoupling caps you are at the mercy of your power supply and wiring to establish your supply rail's on-board AC source impedance at all frequencies above DC. If the supply is an alkaline battery hooked up with 2 inch wires, then this might not be too bad for some simple analog circuits, but in general you should add your own on-board supply bypass caps to be sure.
RadioRon
RadioRon is offline   Reply With Quote
Lots of op-amps. Need ideas on what to do with em. pkshima Electronic Projects Design/Ideas/Reviews 10 4th May 2005 12:21 PM
is reading lots of schematics the best way to learn? psasidisrcum General Electronics Chat 17 18th April 2005 08:57 PM
Jumpers! 2camjohn General Electronics Chat 2 16th June 2004 09:43 PM
Require help on jumpers sename Electronic Projects Design/Ideas/Reviews 1 20th January 2004 12:06 PM
Ics and Jumpers Cyclone General Electronics Chat 5 3rd October 2003 03:30 PM
