Old 8th February 2008, 12:22 AM   (permalink)
razzler is on a distinguished road
Default Stacking In Line Maze Robot
I'm doing a line maze robot without the use of a microcontroller. I use backtracking to determined the correct paths and store them in memory but the thing is, after the robot reaches the end goal, it has to go back and traverse the successful path back to the start line.My instructor advises us to follow a stacking algorithm but how do we determine that the data inputted is that of the successful path??
please help...
razzler is offline   Reply With Quote
Old 8th February 2008, 03:57 AM   (permalink)
Experienced Member
Torben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to allTorben is a name known to all
please help...
When you say "without the use of a microcontroller", do you mean your control software is running on a PC or similar?
A stack should do the trick. Think about what happens as the robot moves through the maze: as you explore each new segment, push it onto the stack; if it's a dead end, backtrack to the previous unexplored segment branch and pop the bad segment off the stack. What's left when you finally make it to the end of the maze is your path.
Torben
Torben is online now   Reply With Quote
Old 8th February 2008, 04:12 AM   (permalink)
i'm using a combination of common ICs that would be some comparators and counters and memory.
btw, thanks. it's much clearer now. ^_^
Old 8th February 2008, 05:16 AM   (permalink)
Experienced Member
Glad to have helped. Pretty impressive doing this without a uC or PC. We get a lot of cries for help on this board from "final year engineering" students whose schools (or instructors) don't seem to teach them anything.
Good luck with the project!
Torben
Old 8th February 2008, 05:19 AM   (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
Send a message via Skype™ to Krumlink
To store data like that it will be near impossible, unless you have a ton of space for transistors. Stick to MC.
MechTronics
Krumlink is online now   Reply With Quote
Old 8th February 2008, 05:33 AM   (permalink)
Experienced Member
. . .except he said he's using memory ICs, so as long as he's got the support circuits and clocking down he should be good to go.
Torben
Old 8th February 2008, 05:34 AM   (permalink)
Moderator
Oh, I diddnt see that. I thought he wanted to just use comparators
It would still be easier to use a Microcontroller.
What exactly is the maze supposed to be/solved?
MechTronics
Old 8th February 2008, 11:20 AM   (permalink)
yup...the instructor expects the maze to be solved by the robot...^_^;;;
any more ideas?it'd be great help ^_^
Old 8th February 2008, 07:35 PM   (permalink)
Super Moderator
I don't see as you're going to 'solve' a maze in hardware?, it would be far too complicated.
However, you could get your robot to the centre by simply following the left hand wall - but that isn't really 'solving' the maze.
Old 9th February 2008, 04:13 AM   (permalink)
the block diagram is like this
robot sensors->control logic->counter->memory
we'll be using a 4x1 MUX as our control logic and maybe a binary counter
what do you think?
Old 9th February 2008, 05:01 AM   (permalink)
Experienced Member
Pommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to beholdPommie is a splendid one to behold
Sounds like a near impossible task to me. You would end up with something like the early pong games. A board about 20 inches on each side fully populated with ttl chips.
Pommie is offline   Reply With Quote
Old 9th February 2008, 11:39 AM   (permalink)
is it?how so?
Old 9th February 2008, 01:14 PM   (permalink)
Super Moderator
is it?how so?
Because you need a computer - so you're going to need to build one from scratch!.
Old 9th February 2008, 02:35 PM   (permalink)
so our instructor gave something impossible to do so I'd most likely fail
Old 9th February 2008, 03:19 PM   (permalink)
Super Moderator
Depends what you mean by 'solve'?
line and light tracking robot Polite3tol Electronic Projects Design/Ideas/Reviews 0 26th January 2008 01:24 AM
line tracer robot lukeXtear Electronic Projects Design/Ideas/Reviews 4 8th January 2008 02:27 PM
suggest me something that can upgrade line following robot fatal_error Robotics Chat 6 26th August 2007 02:38 PM
Questions about a line following robot mattg2k4 Robotics Chat 14 30th March 2007 12:19 AM
Line Following Robot Omar.M Robotics Chat 21 19th March 2007 02:04 AM
