| i have given a picture of the pin configuration of a optical mouse sensor. i need to connect the o/p (high or a low) to a counter so how to i connect it to the ic(and gate in this case). what about the other pins except supply. do i need to ground them or let them be just there or what??and i am using a 4516 for my updown counter is it k?
__________________ i would explain it to you but it would make your brain explode! | |
| It's designed to connect to a processor, you're probably going to struggle using simple logic chips?. You would need to connect ALL the pins, as required by the datasheet, none of them are unused. | |
| The serial interface is the problem it could be SPI or I2C or USB, as it clocks serial data out there is no simple way of just hooking up a counter. 1 interruption will send 8bits?(example only) and 2 interruptions will send 8bits, it's the coding in the bits that tells the story. | |
| Object Counter Circuit | extremeads1 | Electronic Projects Design/Ideas/Reviews | 2 | 18th July 2007 12:56 PM |
| differential op amp circuit? | prh | Electronic Projects Design/Ideas/Reviews | 11 | 14th December 2006 05:22 PM |
| need help with counter style circuit.. | richyyo | Electronic Projects Design/Ideas/Reviews | 6 | 14th November 2005 01:39 PM |
| Ultra low power switching circuit & DC to DC converter t | fastenjaw | Electronic Projects Design/Ideas/Reviews | 15 | 16th November 2004 10:57 PM |
| HELP!!!!...counter circuit | dorai007 | General Electronics Chat | 3 | 14th September 2004 07:38 PM |
