| Experienced Member | Hi, I need to have one switch turn on power to my airplane (rc) reciever and also turn on a 1.2v battery for my engines glow plug. I'm guessing I could hook everything up but I need to keep the 1.2v battery from feeding into the 6v pack and visa versa. Some diodes? Thanks for any help |
| Experienced Member | What you need is a double pole double throw (google dpdt) switch. These are effectively two switches in one package. What I don't understand is that normally you would switch the receiver on permanently but the glow plug would only be powered until the engine is started. Mike. |
| Experienced Member | Quote:
| Experienced Member | Man I totally forgot about a dpdt switch I have a few brand new ones I can use. As far as the glow plug. I am running a 4 stroke engine. To make matters worse it's inverted and it's in my brand new Yak 3D. I plan to run the glow plug hot at all times. Four strokes have a tendency to die out on low idle and/or on throttle blips no matter how well you adjust the low end or high end needle. I fly 3D and this plane is for competition. Flying 3D, like hovering, requires a lot of throttle input and 1-12 inches from the ground in a hover is not a good place to lose your engine. 4 strokes always have a problem keeping heat in the head compared to a 2 stroke thus why they make deeper glow plugs with a heat bar. I do have a few 1.2 volt C cell Nicads I could use but due to weight I would rather use a lipo battery. I need 1.2v to heat the glow plug. My lipo I have on hand for this job is 3.6v. Any way to bring this down to 1.2v without burning the other 2.4v to waste? |
| Experienced Member | Why not use something like this: http://sonictronics.com/xcart/home.php?cat=310 I have also seen something that senses the resistance of the glow plug and applies heat as needed, but I can't find the exact source right now. Continuous draw may take a pretty good size battery to last a whole flight, and using a linear regulator on a LiPo just throws away the excess energy as heat. John |
The time I need it most is at start up and while hovering or other similar tricks. So the Lipo is a no go since I will have to burn the remaining voltage? Suck you can just bottle neck the voltage down with out throwing away the rest to heat. | |
| Experienced Member | Sounds like an option. I am running digital and not analog system so interference should be 0%. |
| Experienced Member | Years ago, my 2-stroke airplane engines stopped when the glow plug's battery was disconnected. The engine was at a high RPM not just idling. It turned out to be caused by a new fuel that didn't have enough nitro in it. Maybe you can spice up your fuel instead of carrying a battery.
__________________ Uncle $crooge |
| Experienced Member | Thanks for the advice. I use high quality fuel. This issue is typical of 4 strokes, especially one mounted inverted.. The engine run great and if it was a typical plane I wouldn't give it a second thought but seeing as I will be flying 3D one little blip or worse the engine dies while I'm in a hover a few inches from the ground its going to smack the ground. Thanks for all your help. |
http://www.romanblack.com/smps/smps.htm You'd need to adapt the circuit for the lower voltage though. Why not just save yourself the bother and use a 2600mAh NiMH cell? | |
Yea, I had thought of that. I have a few battery packs rated at 2200mAh AA cells. I could run 2 or 3 in parallel and bump the 2200 to 4400 or 6600. Just run a bar across all the tops (+) and then a bar across all the bottoms (-) right? keeps it at 1.2 volts and adds the mAh rating per cell, times each battery. Is this correct? | |
| Experienced Member | Paralleling battery banks can cause problems if they aren't all charged equally. You can buy 2600mHA AA cells; you only need one for your glow plug. |
| [help] Power consumption issue on bullet counter project * | Lanzer | Electronic Projects Design/Ideas/Reviews | 13 | 26th August 2005 06:06 AM |
| help needed in switch mode power supply design and anaylsis | mikechamboko | Electronic Projects Design/Ideas/Reviews | 0 | 1st March 2005 06:13 AM |
| Here is a list of semiconductor prefixes. | TPS | Datasheet/Parts Requests | 0 | 21st December 2003 07:24 PM |
| Identify Semiconductors by prefixes | mixos | Datasheet/Parts Requests | 0 | 10th December 2003 06:55 PM |
| MOSFET battery power switches -- can't find any I need | Brocktune | Datasheet/Parts Requests | 3 | 23rd May 2003 03:09 PM |
