Old 1st February 2008, 05:54 AM   #1
Default Triac on PIC Output hardware help
Hi I want to confirm about this circuit. I’m not sure about the TRIACS M1 connects to the correct place?
Any adjustments do I have to do?
Please don't' tell to use an opto isolator here no place to buy them I have only BT136 triacs.
Suraj143 is offline
Old 1st February 2008, 10:51 AM   #2
BANG!!! - what's that zener doing where it is?
Old 1st February 2008, 12:15 PM   #3
The above method is working(i mean 4.5V is coming). what about the M1 terminal does it need to connect to Neutral?So VSS & Neutral connecting both?
Suraj143 is offline
Old 1st February 2008, 12:21 PM   #4
If it's working then what's labelled as a transformer can't really be that, or it's going to die (along with the zener) fairly shortly.
How have you 'invented' such a non-workable circuit?, you've certainly never seen anything wired like that!.
Old 1st February 2008, 12:24 PM   #5
I mean its not working but the 4.5V is coming to the PIC.
But still I'm confused with that M1 terminal.Don't know where to fix.
Suraj143 is offline
Old 1st February 2008, 01:55 PM   #6
It obviously has to go to the neutral, but don't leave the zener wired like that, it's WRONG and something is going to die because of it - wire it properly.
hardware, output, pic, triac
Quik PIC Programming kit Krumlink General Electronics Chat 5 28th January 2008 12:27 AM
Problems switchin relay with PIC Andy1845c General Electronics Chat 5 17th November 2007 07:14 PM
Output = Input - Problems adamthole Micro Controllers 20 24th April 2007 05:09 AM
555 timer output help for a newbee... WIZARDSV650S Electronic Projects Design/Ideas/Reviews 6 6th April 2007 05:04 AM
Function Generator output driver evandude General Electronics Chat 6 31st January 2005 08:49 PM
