Old 26th January 2008, 03:19 AM   #1
Default Ferrite core transformer circuit
I have a ferrite core transformer and it was out of an old radio i was wondering could i use it with other parts to make a simple plug into the wall power supply? something very basic. Also if there are any other interesting ideas to use it for i would like to know.
andynerd is offline
Old 26th January 2008, 03:40 AM   #2
I don't think so since it's probably designed for a much higher frequency than the 50/60Hz from a wall. Maybe someone else knows for sure.
dknguyen is offline
Old 26th January 2008, 07:09 AM   #3
talking about a power supply you might use it for a switching power supply to be supplied by a battery.
I wouldn't use a switching frequency higher than 20KHz since the part was obviously used as an AF-transformer. If the low impedance side has a center tap you can use a timer circuit and switch ground to the outer taps alternating and tie the center tab to +UB. Use the original primary winding for output.
Rectify the output voltage which will be square wave AC.
Connect a load to the new DC and see what happens. If the transformer starts smoking the load is too heavy.
Boncuk
Boncuk is online now
Old 26th January 2008, 11:57 AM   #4
Transformers are used at powerline frequencies as well as audio and radio frequencies. Since the transformer came out of an old radio it could be any of them. The power and audio transformers I am used to seeing in old (a relative term) radio are laminated rather than ferrite.
stevez
stevez is offline
Old 26th January 2008, 12:23 PM   #5
Likewise, I wouldn't expect to find a ferrite cored power transformer in a radio, more likely to be an RF transformer if anything?.
Nigel Goodwin is online now
Old 26th January 2008, 12:43 PM   #6
That sounds most likely but that still doesn't give use enough information, it could be 455kHz or 10.7MHz for all we know. The origional poster really hasn't given us enough information to go on.
if I know the answer.
Hero999 is offline
Old 26th January 2008, 12:45 PM   #7
If the poster correctly identified the core material as ferrite I would agree that it's likely an RF transformer. It's also possible that the OP is using ferrite rather than a broader term - ferrous - for what might be laminated iron. A picture would be helpful.
stevez
stevez is offline
Old 27th January 2008, 02:18 AM   #8
it was hooked up directly to the power cord probably was used to convert the AC voltage to a lower usable DC voltage.
andynerd is offline
Old 27th January 2008, 03:25 AM   #9
a picture or at least a more specific describtion would certainly help as already posted, e.g. dimensions and the number of taps in and out.
Is it a toroidal transformer?
Old 27th January 2008, 05:58 PM   #10
here you go a picture
andynerd is offline
Old 27th January 2008, 11:58 PM   #11
That looks like a normal mains transformer, and NOT ferrite cored.
Old 28th January 2008, 12:02 AM   #12
ahh whatever nvm this was a dumb question i was thinking it was based off the pictures on the internet really i have no clue what kinda of transformers there are and how to figure out what kind they are.
andynerd is offline
Old 28th January 2008, 02:44 AM   #13
Default Transformer
The picture proofs that the device is an everyday's iron core mains transformer. Leave it like it is, connect the black two wires to mains and measure the output voltages. There should be two voltage outputs, one with a center tap.
To find out which wire belongs to which winding measure the resistance between wires. The winding with the center tap should have the double resistance from outer to outer tap.
You can also find out which wire belongs to one winding by looking sharp where they come from.
Old 28th January 2008, 07:50 PM   #14
then the transformer is pretty useless isn't it?
andynerd is offline
Old 28th January 2008, 08:14 PM   #15
Well I think that every transformer is usefull if you can finde use for it (HOW DEEP) I like philosophy ;-)
Aude, Vide, Tace
pitronix is offline
circuit, core, ferrite, transformer
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 13 19th February 2009 07:27 AM
Please analyze this circuit.....for energy meter testing tkvenki Electronic Projects Design/Ideas/Reviews 6 11th August 2008 01:08 PM
Mains ground point and circuit ground point Johnson777717 General Electronics Chat 9 1st September 2007 11:19 AM
Activating a circuit using a photocell mtrails Electronic Projects Design/Ideas/Reviews 5 10th May 2006 06:13 AM
Time Delay Relay Circuit.....is this doable? Draguen General Electronics Chat 14 31st August 2005 05:02 PM
