| Hi all. I hope you can help, this is driving me nuts. Attached is the DXF (zipped) of my circuit. The problem is the potentiometer isnt allowing me to properly adjust the charge point. Normally it is set near full clockwise, which sets it to the lowest possible charge threshold, around 12.5V When a battery below this is connected, the Fast Charge LED lights and the battery begins charging. So currently, I cant seem to set the threshold properly which is most likely a resistor value issue. Some values are slightly off. I corrected one resistor which seemed to fix the threshold setting but the charger never seems to want to cut off at all once it starts! My questions are: What mode are the op-amps running in? What tells the charger to stop charging? My guess is over-current protection What is the best way to troubleshoot this circuit? What is the best way to set and test this circuit? How much is Xanax? Arggh. Thanks for any help. Cloud | |
| Can you convert it to a .gif or .png | |
| Attached now includes a WMF (windows MetaFile) which can be viewed with Windows Fax/Picture viewer. | |
| So in researching I see that the OP amps are set up as Comparators. Makes sense so far. I am still abit confused on what exactly tells the charger when to stop charging. See the voltages listed above the nodes near the input of the op amps? Are those correctly calculated based on the VREF of 6.8V? Also, is it normal that my CR6 6.8V Zener ref should actually show 6.5V. A normal diode I would expect this but I expect this one should always be 6.8V. Regardless I can see how the VRef being off, or resistor tolerances being an issue here. | |
| I don't see how that can work. Can you point to a web site, or otherwise provide a description of how it is supposed to work? | |
If you arent refering to the schematic could you clarify please. Thanks, Cloud | ||
| Additionally I am baffled as to why I have 13+V on every pin of Q4 regardless of charge state or charge threshold. Peculiar. | |
the B series are + or - 5%. In this case it is normal to be 6.8 + 0r - 0.34 volts. So yours in within tolerance.
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | ||
EDIT: I tried to simulate this with not much luck, but I'll try a little bit longer. Last edited by Roff; 24th January 2008 at 04:17 AM. | ||
Thanks for the replies both of you. I agree with you observations. I can actually see a change in the output current by changing the fast-charge potentiometer as well in addition to it affecting the cutoff voltage. Does it seem correct that Q4 (TIP145) has 13V (or more) on every pin? What are some conditions that would cause Q4 to be always on? Also how critical are the diodes (except the zeners) to the operation? I mean what purpose does each serve? | ||
| I tried to manually force the charger to stop charging by shorting Q3 but what happens is the Power LED is cutoff but the Fast Charge stays illuminated. Ps - I believe at least 1 or 2 of those diodes are used for clamping. | |
| Here is an observation. The overcurrent protection is a negative feedback loop. None of the diodes are for clamping. | |
| Thanks again for your input Ron. With knowing that, I disconnect C3 which creates the negative feedback loop and what I see is that the chargers cutoff and turn on values are the same. The charge light blinks on and off when it is triggered (by adj the pot). So that is pointing to a problem in the fast charge negative feedback loop for some reason. I checked the capacitor (which is not polarized). Do you have any more insight with that being said? | |
The fast charge loop looks to me like positive feedback, and removing C3 just speeds up the output of its op amp. I don't understand what that circuit is supposed to do, but I don't see how it could do much, due to the fact that R1 is only 51 ohms. The overcurrent loop is definitely negative feedback. Current above the threshold starts to turn on Q2, which steals current from Q3 (and in turn, from Q4). This should tend to limit the current to about 4 amps (400mv/0.1 ohms). Simulation bears this out. Last edited by Roff; 24th January 2008 at 11:50 PM. | ||
| constant voltage, constant current Lead Acid Battery Charger | Erwin_Macaraig | Micro Controllers | 1 | 4th October 2008 01:26 AM |
| Battery Charger with auto shut-off feature | hardcore misery | Electronic Projects Design/Ideas/Reviews | 134 | 12th February 2008 09:20 PM |
| Lead Acid battery charger | manojp01 | Electronic Projects Design/Ideas/Reviews | 5 | 29th January 2008 06:17 PM |
| Battery charger help... | dieselmo34 | Electronic Projects Design/Ideas/Reviews | 14 | 18th December 2006 06:30 PM |
| Battery charger for mobile phone Motorola | 2PAC Mafia | General Electronics Chat | 0 | 4th October 2005 04:20 PM |
