| I'm looking to build a simple 1mv peak to peak square or sawtooth generator that will fit in my shirt pocket. I'd like the frequency around 65hz. Should I use a timer or does someone know of something simpler? Any help will be appreciated. tacHammer arklamed@sbcglobal.net | |
| Can you just generate a regulator wave, step it down with a resistive divider buffered by an op-amp buffer followed by a AC pass capacitor (to remove offset from the op amp, since 1mV is pretty damn small compared to the mV-order offsets on most op-amps). 65Hz is really slow so I would think a capacitor timer, like a 555 timer would be best. | |
Pocket sized ECG simulators cost $1,400.00 and that's not an affordable option. Thanx for your reply. | ||
| Ha! You are so right. Correction apprecaited. 65-70bpm is what I meant not 65-70hz. Sorry. Rick | |
| Is this a one-off, or do you need a robust design that doesn't require any adjustments? Does it need long battery life? Can you use surface-mount parts, or do you need to use common thru-hole parts? | |
Thanx, tacHammer | ||
| Just use a 555 timer to generate your signal, then a simple resistive attenuator to drop it down to 1mV. | |
Update: Here's one that's a bargain at only $250: http://www.ecgsimulators.com/prod02.htm Last edited by pc88; 26th January 2008 at 12:15 AM. | ||
Thanx for your reply. What you can't see in that photo is the unit is laying down and is much larger than it appears in that picture. I have a simulator that is smaller than that one but what I want is one that will fit in my shirt pocket. The $1400 unit will do much more than just emit a 1mV wave at 60-70bpm. You can adjust it from 30 to 120bpm and from .5mV to 2mV and it even has arrhythmias built in. I have a simulator that can do all that if I need it but I just want something that can simply use to test whether a telemetry transmitter is working or not by putting a waveform on the central station monitor. If I wasn't so lazy and hairy chested I could just put electrodes on myself. I guess that's what I should consider. | ||
| Sounds like this is an opportunity for a uC project. The size would only be determine by the user interface (leds, buttons) and connectors and the battery. Hmm.... (can you hear the wheels turning?) | |
| Here's a 555 circuit, like Nigel suggested. It should run on a couple of AAA's for months (years?). There are several CMOS 555 models - TS555, LMC555, ICM7555, ZSCT1555, etc. | |
| tacHammer, From a former Biomed Tech...a LM555 EKG simulator was a project I built in my Medical Electronics class back in 1974. What goes around comes around. Ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |
| Sine wave generator | ebuka_2 | General Electronics Chat | 4 | 28th July 2007 09:39 PM |
| Triangle wave generator | 4electros | General Electronics Chat | 6 | 14th January 2006 04:41 AM |
| Sine wave generator | Square101 | Electronic Projects Design/Ideas/Reviews | 2 | 21st May 2004 08:38 PM |
| Sine wave generator | nohams | Electronic Projects Design/Ideas/Reviews | 1 | 24th November 2003 12:12 AM |
| alpha wave generator | koton666 | Electronic Projects Design/Ideas/Reviews | 2 | 10th September 2003 02:03 PM |
