Old 23rd January 2008, 02:00 AM   (permalink)
Default Terminator poster project - help/advice
Hi there,
I've finished the schematic of my current project.
This is the first time Ive ever really drawn my circuits out on paper.. I used eagle AutoCad..
Does it look the way it should?
I m using the internal 4mhz clock.
Once problem.. the 5v regulator is getting rather hot.. even with a large heat sink..
Im guessing this is because it is going from 24volts to 5volts..
Could I use a voltage divider to distribute the heat over a couple resistors?
Could anyone tell me how to do that?
Again im really new to drafting schematics .. any advice or pointing out of flaws would be really helpful
"Stick around" - Arnold Schwarzenegger in The Predator after impaling a soldier to a wood post
9vDC Guitar Pedal PSU
PIC16F84a Game Module
Peter_wadley is offline
Old 23rd January 2008, 07:19 AM   (permalink)
You can try a slower clock speed by changing the OSCF bit in the PCON register to save power.
You could put a resistor in series with the input to the regulator. You'd also need a cap (0.1uF) across pins 2 & 1 of the regulator. You'd need to measure the maximum current drawn by the regulator (Probably when the max number of the transistors are being turned on by the PIC) and then use ohms law to calculate a resistor value that would give you around 10V at the input of the regulator at the minimum input voltage on the 24V line. If the transistors were all FETs, current draw wouldn't be an issue. Changing them to darlington's would also work. You may be able to also just get away with less base current and use higher value base resistors. Depends on the beta of the transistors and the LED current.
kchriste is offline
Old 23rd January 2008, 10:41 AM   (permalink)
I spy 13 leds.
If each LED takes 20ma then thats 260ma
A 7805 with a 24v input and 5v output has to drop 19v at 260ma.
Thats a good 5 watts of dissipation
picbits is offline
Old 23rd January 2008, 10:57 AM   (permalink)
Originally Posted by picbits
I spy 13 leds.
Actually theyr'e just 12 LEDs. One is not connected to R29.
Boncuk
Boncuk is offline
Old 23rd January 2008, 11:05 AM   (permalink)
Boncuk
Good eye Good eye
but actually your both mistaken
Each LED represents either 4 or 11 LEDs.. since I only need once place to connect them on the PCB.. in actuallity they are on the Poster.
Sorry pic but i think you are also mistaken regarding the current.
The LEDs are being driven by the 24v rail
the 7805 is actually in parallel with the LEDs.. yes it is dropping 19volts and from using my multimeter I have found that the current of the microcontroller - will all the transistors are active.. is 60 ma .. which is 1.15 watts
is there a proper way to reduce the power dissipiation of the regulator?
I will fix the unconnected resistor - thanks!
Old 23rd January 2008, 11:10 AM   (permalink)
Hi Peter,
come on, Eagle schematics can look better, e.g. having VCC and GND symbols too, and labels at the input and output connections of the PIC. You'll find it very useful when you route the traces on the PCB.
A german saying: "A good horse never jumps higher than it has to", meaning why do you put in 24V just to supply one lousy LED from each output?
Putting in 9V you still have enough to play with.
A fixed voltage regulator tends to oscillate and consequently gets hot. Therefore a decoupling capacitor of 100nF on both, input and output pins connected directly to the ground pin is an absolute 'MUST'.
Using a heatsink like the SK104 you'll never get a hot voltage regulator provided you decouple it properly.
Also use a small electrolytic capcacitor (47 to 100uF) at the regulator output. The PIC will appreciate that very much.
Kind regards
Hans
Boncuk is offline
Old 23rd January 2008, 11:17 AM   (permalink)
hey boncuk,
thanks for the advice!
would you mind posting some examples of your eagle schematic?
I think the power rails are what I am screwing up.
thanks
Old 23rd January 2008, 11:20 AM   (permalink)
Oops - bit early in the morning for me to be reading schematics
picbits is offline
Old 23rd January 2008, 11:53 AM   (permalink)
Hi Peter,
here is just one example. If you want more, I'll send the original eagle.sch files via email.
I'm using Eagle version 3.55 although I also have Eagle 4.16. It is only slightly better than the older version. The autorouter surrounds itself as usual.
Making PCBs I import the board files into the new version, because labels are better readable (another type of characters)
Hopefully that file is "readable" at all.
Regards
Hans
Boncuk is offline
Old 23rd January 2008, 09:15 PM   (permalink)
Peter,
You saved your schematic as a fuzzy JPG file type instead of a very clear GIF or PNG file type.
Will you have up to 11 red LEDs in series (?) and is that why the unregulated supply voltage is so high?
Use a small heatsink for the regulator.
audioguru is offline
Old 25th January 2008, 01:08 AM   (permalink)
How is this Boncuk?
Is this better?
Yes audio, that is exactly why.
I have redone the schematic..
Adding power labels and symbols
I have also given names to the resistors and LEDs...
You're right it does help when transitioning to the PCB
The poster read: The Terminator... if that helps understanding the name convention used.
As you can see the resistors, which limit the LEDs, vary in number and ohms due to different numbers of LEDs per letter.
This way the current is kept relatively consistent.
The button will be used to cycle between different lighting patterns.
The output to music will be used to signal another PIC to begin playing the Terminator theme.
I would like to make the PCB tonight, however, I haven’t a laser printer currently.
also added in cap values
Old 25th January 2008, 02:24 AM   (permalink)
Thank you for saving your new schematic as a very clear PNG file type. It uses 18% of the bytes of the fuzzy JPG file type one.
Old 25th January 2008, 03:26 AM   (permalink)
Originally Posted by Peter_wadley
How is this Boncuk?
Is this better?
Hi Peter,
it is better, but you don't seem to know an obvious secret about Eagle. Most of your part numbers are overwritten by the part itself. It simply looks ugly.
For a good and perfect schematic use the function "SMASH" (within your tool bar) After having smashed a part you'll see reference crosses for each part, name and value. Switch the grid size to 1/40 inch and move the part number and/or the value to a position which makes the part easy to identify. Use the same grid size also when labeling nets. You might also change the ratio of the letters from (standard) 8 to 6 to obtain a very clear and neat picture. (Function: Change -> ratio). Manually type in 6 to overwrite the 8.
BTW, you can also use Eagle to make technical drawings using the schematic editor. The only problem: You cannot get relative angles and distances. To change that you can move the point of origin. E.g. you want to draw a horizontal or vertical line of 2inches length starting somewhere on the sheet. Select a start point and move the 0/0 origin there. Draw the line observing X and Y coordinates. Voila, without calculating you've obtained what you want.
Using buses you have to connect lines starting at a present bus. If you join two buses you'll get an error message.
Take a look at the screenshots for clarity.
Kind regards
Hans
Boncuk is offline
Old 25th January 2008, 04:51 AM   (permalink)
you could shift the dissipation to another component, or group of components, but you're still left with the same amount of energy to burn off
toss a heatsink on the regulator and call it done, or build a SMPS ... either monolithic which is easy and expensive, or discrete like the Roman Black regulator which is cheap and perhaps easier to understand but has a messy bunch of components that modern wafer level integration has provided for us in a single tiny chip.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 25th January 2008, 06:00 AM   (permalink)
Thanks for the tips Boncuk, Audio, and justDIY
Here are some updated schematics and the PCB layout
Ive rearranged the names on the schematic using smash.. looks great
For the PCB layout..
I was going to use the autorouter .. but then I asked myself why I would want a mindless algorithm sort my layout..
Im sure it the autorouter has many uses and is great when you've learned how to adapt it well.
I think ill just stick to the couple hours of manual labour.
It is niceto have eagle pre place all the components when switching from the schematic to the board !
I will use the heat sink for the regulator.
thanks
Uni Project Advice 2-tone Electronic Projects Design/Ideas/Reviews 7 18th October 2007 01:11 AM
My professor screwed my final electronics project! kungfusansu Electronic Projects Design/Ideas/Reviews 21 26th August 2007 10:57 PM
FINAL YEAR PROJECT! erique82 Electronic Projects Design/Ideas/Reviews 18 15th April 2007 11:09 AM
A Microcontroller based Analogue Waveforms Analyzer Project km Electronic Projects Design/Ideas/Reviews 76 30th June 2004 07:40 PM
I need a project idea based on my strength or interest. :) janetsmith2000@yahoo.com Electronic Projects Design/Ideas/Reviews 10 11th November 2003 10:33 AM
