| Oops, missed it thanks so much.
__________________ Regards, William Mullaney "HOPE for the best, EXPECT the worst, ACCEPT whatever comes." http://wiliamsville.myminicity.com/ http://wiliamsville.myminicity.com/ind/ http://wiliamsville.myminicity.com/tra/ http://wiliamsville.myminicity.com/sec/ | |
| You may need a power switch anyway as you will need the WPUs for the switches. These are around 20k and so can draw a significant current. I guess a simple way around that would be to use 200k pullup/downs on the switches/bulbs. Mike. | |
| Well the pullups only matter if the switches are on. | |
| Dumb question, should I add clamp diodes for the small bulbs? (6.3V 200ma) driven by a 2N2222 transistor. | |
Lefty
__________________ Measurement changes behavior | ||
| Probably not, but since I have so many diodes I might.
| Alright then, I won't.
The timer allows you to reorder the switches without changing any bulbs. I am adding the sense resistors regardless. It can be built either way.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| So, Bill, are you going to make it a kit? When done how many $$$ will it be?
| This is an updated version that includes bulb current sensing. It can be built with bulbs or LEDs. To use bulbs short the 4 SMD jumpers. To use with LEDs install 4 current limiting resistors R10-R13 over the top of the SMD jumpers. To use bulb sensing install R4-7 and the 4 jumpers shown in RED on the top side of the board. Install the MCLR jumper that snakes around the chip to the ICSP connector. The route shown here is not a good one. This jumper will not exist in the next rev in that there is a possible route. EDIT: There are a few things here that are a bit odd. Mostly due to the now quite ready for prime time beta version of Eagle that I am using. But I do not see anything that should keep it from working. EDIT2: Schematic unchanged. Removed the MCLR jumper and routed it on bottom layer. Decreased Isolate to .032. EDIT3: Schematic unchanged. Very small change to layout. I am removing the .png for the foil and replacing it with a PFF which is much clearer. There is also text file which is actually a GCODE file to drill the PCB on a CNC machine. You must rename this file to work with you CNC software, maybe .nc or .t EDIT 4: Schematic unchanged. Board to ver 1C2. Moved processor to make more room for switch connector. Replaced foil.pdf with foil_1C2.pdf.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 24th January 2008 at 05:20 AM. | |
| CopyLeft3007 3v0 Can I know how do you add the ground traces on the empty space? Thanks
__________________ Superman returns.. | |
| POLYGON GND If you ground is called GND The distance between the GND fill and other signals is set by ISOLATE.
| Is this setting done in the schematic before converting it into layout? I always start directly from the layout and route manually. That's why it takes me very long time for designing the PCB.
In the board editor there is a command line box just above the main work area. It is here that you type POLYGON GND. But if you did not create the board from a schematic it can not know which traces belong to GND or any other signal. Take the time to learn the schemaic editor. It is worth the effort. Help is here if you need it or also on Eagle's email list. I changed the board to get rid of the MCLR jumper. You may want to look at it.
| Question about Inchworm+ | Quan | Micro Controllers | 54 | 28th October 2007 01:21 AM |
