| Students will like it, but the real fun will be the other teachers. Sort of funny. You doing the programming and me the hardware..... EDIT: If you want a board I can make two. Connectors are all .1 pinheaders. Last edited by 3v0; 21st January 2008 at 02:46 AM. | |
| I'd love a PCB, and thanks Marks256 for the food colouring tip. PS the code will be interrupt driven, of course you can change it as it'll be trimmed down to simply work. Two interrupts, TMR0 (about once per second) will update a counter and sleep / reset INT_on change PORTB for the switches That's all you need really. | |
__________________ --- The days of the digital watch are numbered. --- | ||
| We still need to come up with switches for the thing. Any ideas? kchriste: Thanks for looking. I do not plan on making more then a few boards. On the ones where I know LEDs will not be used I will put traces between the pins of the jumpes. What I posted was generated by Eagle's EXPORT>IMAGE. I do not think the holes will be offset if I print it directly from Eagle. The again it was the new beta version, Krumlink: Let me know if you want one ?
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | |
| I vote homemade knife switches. But then again, this isn't my project... I think they would be fairly easy to make.
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | |
| Off PCB toggle switches are pretty common. SPST is all one needs. | |
| Knife switches are cool but I do not think they go well with the illusion. The regular switches and bulbs make people think it is simple not strange. I have seen switches with handles like a rod. One could slip caps over them but you would have to find or make the caps. Maybe heat shrink oVer a tube with a magnet sort of thing. Or maybe polyclay.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 21st January 2008 at 04:43 AM. | |
| Coloured (painted) washers might work. | |
| Or small painted wooden dowels with holes drilled in the bottoms with a magnet in them.
| These switches have the option of snap on caps for their K toggle switches: http://www.nkkswitches.com/pdf/Btoggles.pdf You'd need to file the bat handle a bit, or drill out the cap, to make it easier to move the colored caps around.
| This one uses a plastic washer approach. ![]() | |
I sort of missed what you were talking about on the SMD solder pads. The concept is/was new to me. I took a while but I got it. Thanks
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) | ||
| | (permalink) | ||
Bill's idea of colored washers is looking better and better. Just choose an oversized washer that fits over the switch, paint it and drop it over the bat on a toggle switch so it settles on the mounting shaft. Quote:
__________________ --- The days of the digital watch are numbered. --- Last edited by kchriste; 21st January 2008 at 06:18 AM. | |||
But I do think that the removable handles are better for the illusion. It makes the prey think they are fixed to start with. Rev 1B now uses SMD jumpers. See previous post. Anyone who wants to do their own board should download Eagle 4.92 and print directly from it. The foil provided here should work but is not as neat.
__________________ search engine for electronic partsJunebug USB PIC programmer kit., USB Bit Wacker, 3v0's Homepage The 15 Minute Printed Circuit Board! (+drill time) Last edited by 3v0; 21st January 2008 at 07:15 AM. | ||
| Bill, you mentioned a pic16f628a at 35 k hertz, how do you tell the pic to operate at that speed? (It is NOT in the configuration word)
__________________ Regards, William Mullaney "HOPE for the best, EXPECT the worst, ACCEPT whatever comes." http://wiliamsville.myminicity.com/ http://wiliamsville.myminicity.com/ind/ http://wiliamsville.myminicity.com/tra/ http://wiliamsville.myminicity.com/sec/ | |
| Question about Inchworm+ | Quan | Micro Controllers | 54 | 28th October 2007 01:21 AM |
