I looked around some on-line for similar lamp sockets but so far nothing that matched what they used. Search continues. Lefty
__________________ Measurement changes behavior | ||
EDIT: Search for 'mes lamp holder', here's one source http://www.maxiaudio.co.uk/proddetail.php?prod=G016YG Last edited by Nigel Goodwin; 20th January 2008 at 05:17 PM. | ||
| Radio Shack has 'em. I'd prefer leds for now, 3v0.
__________________ Regards, William Mullaney "HOPE for the best, EXPECT the worst, ACCEPT whatever comes." http://wiliamsville.myminicity.com/ http://wiliamsville.myminicity.com/ind/ http://wiliamsville.myminicity.com/tra/ http://wiliamsville.myminicity.com/sec/ | |
| OK I will make it so you can use it with either LED or bulb. Radio shack has E10 Vertical-Mount Bulb Holder (4-Pack) $1.69 Model: 272-360 Catalog #: 272-360 I think you may be able to stuff these into holes drilled into the wood. They also have surface mount plastic bases which cost more. | |
| Those are some ugly bulb holders. Would look good with knife switches ![]() | |
| Screw in bulbs are a must. This gives you some time while trying to screw in the bulbs and BS.. Also they DO make LED lamps, tried to do a quick search for them with no luck. But they have a plastic white bulb. Edit: I've seen them in battery powered candles. I do however think this would look better using huge bulbs that you can see the filament in them. Last edited by JaXz; 20th January 2008 at 07:16 PM. | |
| Been thinking that bright white LEDs that are fixed might work fine, just need removable colored lamp caps to switch around like the switch covers. Lefty
| IMHO LEDs are too high tech and many would figure they contain some form of wizardry inside (like a flashing LED has) Colored LED covers might work but it'll still appear modern. | |
| I think knife switches would really add to the illusion.
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | |
![]() If anyone knows where to find porcelain lamp bases squeak up. Last edited by 3v0; 20th January 2008 at 07:34 PM. | ||
| First cut of a schematic using 16F88. Power with 4 cells. To use with bulbs bypass resistors R10-13 with junpers JP1-4. If you choose to use LEDs you need to polorize the sockets. This should be easy to etch and solder. EDIT: Current version is 1B which uses SMD Jumpers Board is aprox 2.0 x 1.5 inches Updated schematic Added board and foil images 300dpi Will post eagle files if requested Last edited by 3v0; 21st January 2008 at 07:10 AM. | |
| i know this might seem dumb to some of you, but if you cant find colored bulbs, this may work http://www.google.com/url?sa=t&ct=re...R-hA_rsimXLClg it is how to stain glass with glue and food coloring. it is a PDF file. Oh. AND ONLY DO THIS WITH AN ADULT PRESENT!
| The layout of REV 1A is done. I will build a test board mid week. See my previous post. | |
Bet your students will love it. | ||
| Question about Inchworm+ | Quan | Micro Controllers | 54 | 28th October 2007 01:21 AM |
