| There is one section where the magician uses slight of hand. The magician puts two caps in each hand and asks the assistant to pick one hand. The magician discards two caps and distributes the remaining caps such that he has one in each hand. The assistant picks a hand and the magician gives him the red switch cap. The assistant puts the red cap on a switch. The magician flips that switch and the red lamp lights. Can you figure out how that is done ? | |
PM me if you don't want to spoil to for others Lefty
__________________ Measurement changes behavior | ||
__________________ Superman returns.. | ||
It would be good for others to figure it out. | ||
| Hi all G!! this is just killing me Come on please , please , please tell me, even PM. if you have to. I'm sure your not a member of the Magic circle?? Mark | |
| I'm such a dummy, it's obvious! It's about the predetermined sequence of the bulbs (left to right) which dictates which switch he flips.! I think the slight of hand confused me, so it had to be the red cap or it wouldn't have worked. Perhaps having it left to right all the time is too obvious (well even if it did fool a mug like me
| Yes you could set a special reset sequence for right to left, but it fools most. | |
| It's a cool toy, not worth anywhere near $500 though. PS How many do ya think they sold?
__________________ Regards, William Mullaney "HOPE for the best, EXPECT the worst, ACCEPT whatever comes." http://wiliamsville.myminicity.com/ http://wiliamsville.myminicity.com/ind/ http://wiliamsville.myminicity.com/tra/ http://wiliamsville.myminicity.com/sec/ | |
| It's probably so expensive because it's hand made and they only sell a few a week. It does look high quality though. I built a PIC programmer ages ago and haven't used it so this looks like a great idea for my first PIC project.
| This is how I described the action. Use a learning mode and a playback mode. After 10 or so seconds with all switches off it forgets and goes back to the learning mode. In the leaning mode the operator must flip the switches in the same order as the bulbs sequence from left to right. Once the 4th switch is flipped (learning sequence complete) the system enters the playback mode. Each switch will light the bulb that it lit during the learning mode. | |
| Thats sorta how I put it, I deleted my post so you would figure it out on your own.
| Oh..... That makes sense. Bill, let us know an estimate of cost. This would be fun to confuse people with....
__________________ There is no "I" in "team", unless Apple makes it... Then it would be iTeam. | |
| I'm just going to build one. That's an awesome trick!!!!
| Sure, you'll need 4 switches with removeable colored caps, 4 colored light bulbs, 4 driving transistors & a PIC16F628A would be a good choice IMO. A 0.1uf, 1n4148 (drops the voltage a weebit) and 4xAA would be perfect. Run the bulbs directly from the batteries and through a 2N2222A with a 470ohm base resistor should make 6v blubs glow brightly enough. Software should be pretty stright forward. For extra points use the 38khz internal clock (low power, shorter delay loops) and the wake up on portb (with pullups too) and your Magic box will run for ages on a set of batteries and won't need a power switch. | |
| Normally I'd suggest LEDs for this sort of thing but in this case incandescents are a must as we want it to look as low-tech as possible.
| Question about Inchworm+ | Quan | Micro Controllers | 54 | 28th October 2007 01:21 AM |
