Old 13th January 2008, 03:59 PM   (permalink)
Default Trouble with Shocker
I decided to build a shocker that operates at 6V. I build the following circuit. It worked fine and when i powered it it gave me humming sound which means that the relay was switching on and off at very high frequency.
But the problem is when i connected a small mini transformer(Which i got from a my cheap old charger) across point A and B it did'nt worked.
What could be the problem. I know the problem is with the transformer, Can any one tell me which transformer to use??
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 13th January 2008, 04:38 PM   (permalink)
That's because you connected the transformer in completely the wrong place - look at your circuit and think about it!.
Old 13th January 2008, 05:43 PM   (permalink)
I took this as reference:
http://www.electro-tech-online.com/a...f?d=1102621425
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 13th January 2008, 05:45 PM   (permalink)
Well if you say that polarities are wrong in my diagram, then again my circuit is not working because i tried by both the ways
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 13th January 2008, 05:59 PM   (permalink)
Default Shocker
Did you verify that the transformer you used is only a transformer and does not contain any rectifiers? You don't want a rectifier to shunt your generated high voltage, so it must be a true transformer with the low voltage secondary connected across the coil of the relay to give you the required step-up. (Important also is that the impedance of the transformer winding should be approximately equal to the impedance of the relay coil, otherwise the current will have a preference for which ever one has the lower impedance). (Output is on the high voltage side).
Try to find an open type relay and wind a few thousand turns of very thin wire on top of the existing coil if space allows it. This winding can then be used as the high voltage output. (Just a thought!).
JTECH is offline
Old 13th January 2008, 06:27 PM   (permalink)
I didn't say the polarity was wrong, I said you've connected the transformer to completely the wrong place - and it's nothing like the link you posted.
I'll give you an extra clue (although there's almost no components to get confused by) - you've connected your transformer directly across the battery!.
Old 13th January 2008, 06:45 PM   (permalink)
Ok I got it, actually i drew the schematic wrong in hurry. So here's the schematic of the circuit which actually i made.
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 13th January 2008, 06:50 PM   (permalink)
That should work then, although personally I'd probably connect point B to the other relay contact, so it 'makes' as the relay switches.
There's really nothing to go wrong, unless you wire it wrong.
Old 13th January 2008, 06:54 PM   (permalink)
Ok can you tell me which transformer to use. I actually broke a old nokia charger to get a transformer if you can specify one it would be helpful.
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 13th January 2008, 06:57 PM   (permalink)
Was the Nokia a switch-mode transformer?, I wouldn't expect that to work very well.
Old 13th January 2008, 08:06 PM   (permalink)
The relay will expire pretty quickly as they're not designed to work at that frequency.
Screen name: Aloone_Jonez
Hero999 is offline
Old 13th January 2008, 08:43 PM   (permalink)
any alternative to relay??
Actually i am having a party soon in my university so i am in urgent of a shocker . Any help would be appreciated.
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 13th January 2008, 09:26 PM   (permalink)
It's not like you're wanting it to run for days at a time, it should certainly last much longer than it takes to get bored with it - and has the added advantage that it will stop working well before the hospital get around to removing it from where it gets shoved!
Old 13th January 2008, 10:53 PM   (permalink)
I guess when there's no beer; a shocker is good fun at a college party.
Bill
Smart Kits build Smart People
Old 14th January 2008, 01:05 AM   (permalink)
Yup. "Beer is proof that God loves us and wants us to be happy"
B. Franklin
We never have time to do it right; but we always have time to do it over.
Papabravo is offline
Shocker From A Pen Shocker Rand911 General Electronics Chat 16 7th December 2006 01:53 PM
big trouble with NE564 and XR226 Powerwiz Datasheet/Parts Requests 7 12th August 2006 02:14 AM
Trouble programming the config mem on a pic16F628A FlyingDutchMan Micro Controllers 2 25th April 2006 06:11 AM
How do i build a vibrant shocker? thomas76676 Electronic Projects Design/Ideas/Reviews 10 2nd April 2005 03:37 PM
shocker circuit melvin Electronic Projects Design/Ideas/Reviews 6 28th November 2004 06:20 PM
