Old 10th January 2008, 12:18 AM   (permalink)
Default Switching LEDs
This circuit is a portion of the circuit that I am working on, as many could tell, but I have changed my ideas for the operation of the indicator circuit as I call it. I want the Warning LED (Orange) to burn steady until the cell starts refilling, then I want the warning LED to flash until the pump switches off and the cell resumes operation. I plan on using a 555 circuit to make it flash, but my problem lies in switching it from steady burn to flashing using the 555 circuit. I've done started looking at the 555 Circuits that I can use for this purpose. What kind of setup would I use to switch from steady burn to flashing using the 555 circuit? Thanks for any help y'all can give me. I have attached the current circuit diagram for what it is now.
This is the way the world ends,
Not with a BANG
But with a BELCH
BURRRRRRRRRRPPPPPPP
skeeterb is offline
Old 10th January 2008, 12:39 AM   (permalink)
We are the PIC, learn PICs and make your LED projects easy, fun and flexible RESISTANCE IS FUTILE
Bill
Smart Kits build Smart People
Old 10th January 2008, 12:48 AM   (permalink)
If you connect the red LED circuit between the supply voltage and pin 3 of the 555 timer. That is the resistor LED combination with the anode side of the LED to the supply voltage and the cathode side to pin 3 of the astable configured 555, the red LED will flash. Then if you ground pin 4 of the 555 the LED will go on steady.
k7elp60 is offline
Old 10th January 2008, 01:13 AM   (permalink)
Default RE: Switching LEDs
I didn't think of that, but I want the Red LED to burn steady and the Orange LED to flash when the Red LED comes on, but burn steady until the Red LED is turned on. That's what I'm asking. I don't want to mess with PICs right now, that's still above my level of experience in working with electronic circuitry.
Not with a BANG
But with a BELCH
BURRRRRRRRRRPPPPPPP
skeeterb is offline
Old 10th January 2008, 02:10 AM   (permalink)
I never met a project too trivial that it couldn't be done better by a microcontroller
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 10th January 2008, 02:13 AM   (permalink)
It's not that. I feel that I'm not up to that level of experience to use microcontrollers yet. I'm still struggling in the minors or working on fairly low level electronics.
Not with a BANG
But with a BELCH
BURRRRRRRRRRPPPPPPP
skeeterb is offline
Old 10th January 2008, 03:08 AM   (permalink)
Not so tough really, you can even practice for free with MPLAB and its simulator.
Blinking lights is something the PIC does very well, and could hook directly to your diagram at the top of this thread.
Bill
Old 10th January 2008, 03:15 AM   (permalink)
I'm gonna stick with some less difficult electronics, because I have little experience with programming, and don't want to get into that until I want to create a more complicated circuit.
Not with a BANG
But with a BELCH
BURRRRRRRRRRPPPPPPP
skeeterb is offline
Old 10th January 2008, 05:04 PM   (permalink)
What is the voltage in your circuit that is feeding the LED's.?
k7elp60 is offline
Old 10th January 2008, 05:07 PM   (permalink)
the entire circuit is run by 12VDC. That's the control circuit and the indicator circuit. I'm sorry I didn't indicate that when I copy and pasted it from my original circuit. All I need is to switch the Warn (Orange) to burn steady while the Refill LED is off and flash when the Refill (Yellow) turns on. I've been looking at different transistors and FETs that I may be able to use, but don't know what to use.
Not with a BANG
But with a BELCH
BURRRRRRRRRRPPPPPPP
skeeterb is offline
Old 10th January 2008, 05:15 PM   (permalink)
Well it is possible to just add a flashing LED to the circuit. There are LED's that have the flashing circuitry built in. The flash rate varies a little but as I recall it is about 2 times a second.
k7elp60 is offline
Old 10th January 2008, 05:23 PM   (permalink)
hrmm, I didn't think about that, but like I said I only want it to flash when the HHO cell is refilling, but burn steady until the pump kicks in.
Not with a BANG
But with a BELCH
BURRRRRRRRRRPPPPPPP
skeeterb is offline
Old 10th January 2008, 08:11 PM   (permalink)
you're going to need a small pile of logic and analog chips to pull this off, or one microcontroller.
I understand that it seems like there is a lot to learn with microcontrollers, but I don't agree that it's all necessary. Check out the picaxe chips ... they're inexpensive, require no special programmer at all, and have a free easy to use (designed for grade school kids) programming language. you'll have to use a little "glue logic" to interface your various inputs with the chip but it'll still be a lot easier than cobbling something together out of discrete logic and analog circuits.
Favorite numbers:
justDIY is offline
Old 10th January 2008, 08:47 PM   (permalink)
I may just have to leave it where it only burns steady, instead of making it flash. I hate that I won't get to make that idea work like I wanted it to.
Not with a BANG
But with a BELCH
BURRRRRRRRRRPPPPPPP
skeeterb is offline
Old 10th January 2008, 09:20 PM   (permalink)
I still think we can do it with out a lot of circuitry. If the Refill terminal has no voltage until the yellow LED is turned on and the warning terminal has 12V when you want the orange LED operate on both conditions(flashing/not flashing) it can be done two ways one with a 555 timer and an additional transistor(NPN). The other way is with a flashing LED and two transistors(1 NPN and 1 PNP). Both circuits would require a few extra parts but no additional IC's
I am going out of town for 2 days so I'll check when I get back.
As a side note: If the Power,Operation,Warning and Refill terminals have either no voltage or +12V with respect to ground the diodes connected to each LED is not necessary.
k7elp60 is offline
switching a block of LEDs with a PIC? Andy1845c Chit-Chat 16 26th March 2007 07:47 PM
Introduction to High Brightness LEDs and Thermal Management Ocelaris Electronic Projects Design/Ideas/Reviews 3 17th March 2007 06:35 AM
A Basic Question of Efficiency - 4 LEDs in parallel or series!?! Agent M Electronic Projects Design/Ideas/Reviews 9 27th December 2006 04:23 PM
Long-life circuit for LEDs and a clock dabuttery Electronic Projects Design/Ideas/Reviews 4 22nd February 2006 04:16 PM
Question about LEDs and resistors. tribaloverkill Electronic Projects Design/Ideas/Reviews 5 1st November 2004 05:55 AM
