| Experienced Member | some time ago, I posted a circuit that was incomplete. RadioRon helped me out some by giving a logic diagram of the chips I need to make my circuit work. I was asking for the pinout diagram which shows the arrangement of the pins on the IC chip, when ppl griped about me wanting them to do the circuit. I just was interested in the IC pinout instead of the circuit diagram. Looking back at that circuit after time has passed and I temporarily lost interest in the circuit, I have come back to it and want to finish it. In the circuit, when the water level gets below the Upper Water Level Sensor, I want it to turn on a LED, which warns of the low water level in the cell. I changed my mind in the method of turning the LEDs in my circuit, i thought about possibly using a MOSFET or similar chip to control the LEDs. What MOSFETs or similar ICs can I use for that simple switching?
__________________ We are the BORG. Lower your shields and surrender your ships. We will add your biological and technological distinctiveness to our own. Your culture will adapt to service US. RESISTANCE IS FUTILE |
| Experienced Member | Quote:
this much can be expected , i feel.
__________________ Regards, Sarma. Last edited by mvs sarma; 9th January 2008 at 06:57 PM. | |
Edit: I've been doing some searching and found the pinouts for the 4011 and 4093 Logic ICs. I was recommended those 2 ICs, but looking at the pinouts, I probably use only 1 IC for my needs because of the number on Inputs and Outputs available on the chip. Should I use the 4093 w/ Schmitt Triggers or the 4011 IC? Now all i need to get some info on what MOSFETs i can use to act as switches for my indicator circuit, which is shown in the circuit diagram, for when the upper and lower water level sensors pull low, AKA get below the lower water level sensor.
__________________ We are the BORG. Lower your shields and surrender your ships. We will add your biological and technological distinctiveness to our own. Your culture will adapt to service US. RESISTANCE IS FUTILE Last edited by skeeterb; 10th January 2008 at 12:30 AM. | |
| Experienced Member | Can anyone help me figure out this Logic Diagram, so i can figure out which inputs and outputs to use and which ones to leave alone and just connect to ground. Edit: here's more info from RadioRon when he originally posted this diagram Quote:
__________________ We are the BORG. Lower your shields and surrender your ships. We will add your biological and technological distinctiveness to our own. Your culture will adapt to service US. RESISTANCE IS FUTILE Last edited by skeeterb; 10th January 2008 at 04:10 AM. | |
| Experienced Member | Hi Skeeter In the diagram that I provided some time ago, you will notice that there are little numbers beside the wires going into each gate symbol. These numbers refer to the pins on the respective ICs. This circuit MUST use two ICs, you can't use one or the other of the 4011 or 4093. The reason for this is that I have chosen two very different kinds of gates. The gate symbol with a straight line on the left is a NAND gate, while the one with the slight curve on the left is a NOR gate. These two types operate very differently and you have to be very careful when substituting one for the other. So, referring to the diagram, G2 and G3 must be in the 4093. You provide power to the 4093 with Vsupply at pin 14 and GND at pin 7. Pins 1, 2, 12, and 13 must be grounded. Otherwise, G2 is pins 4, 5, 6 and G3 is pins 8, 9 ,10 as shown in the diagram. Gates G1, G4 and G5 must be in a 4011 IC. The 4011 is powered with Vsupply at pin 14 and GND at pin 7. You must ground pins 1 and 2. Otherwise, hook up the pins as numbered in the diagram. In general, you should make sure that your inputs to this circuit do not go higher in voltage than Vsupply nor should they go lower in voltage than Ground. I hope this helps.
__________________ RadioRon |
| Experienced Member | Thanks Ron, I appreciate your help, that will help me with my circuit. I now realize I should have been searching the web for the pinouts for the ICs myself, when I was begging for them back in July. I guess time away from this project has made a difference in my mindset for this project. I wasn't sure what you meant in the logic diagram, because I'm still a NOOB when it comes to designing circuits. You may have noticed another thread that I started here that mainly focuses on the indicator circuit of my project. I've changed how its gonna work, but I'm slowly working it out. I was planning on using transistors and a 555 Astable circuit to make the Warn (Orange) LED flash when the Refill (Yellow) LED is lit. I was trying to figure out a way to switch it from steady burn: Refill LED off, to flash: Refill LED lit. I'm not begging for a circuit diagram, cause I already have some of it already planned out, since I'm gonna use an Astable 555 circuit, and transistors. Its the arrangement that I'm just puzzling over.
| Experienced Member | Here's a little more complete version of the circuit using the reference that Ron gave me, so see what you think and see what changes need to be made. This image excludes the indicator portion that I am working on in a separate thread here. Tell me what you think about this circuit and i need to change to look better or what might be needed. I'm working on adding the indicator circuit, but until I get that portion done, the circuit diagram is going to be incomplete.
__________________ We are the BORG. Lower your shields and surrender your ships. We will add your biological and technological distinctiveness to our own. Your culture will adapt to service US. RESISTANCE IS FUTILE Last edited by skeeterb; 11th January 2008 at 07:39 PM. |
| Experienced Member | I know I'm bumping this thread, but I noticed that some gripes have been posted about me spreading out my information and request to a bunch of different threads. So, I am using this old thread to update everyone on the status of my circuit. I have redesigned it using Eagle and have tried to reduce the size of the circuit schematic diagram and have actually made some progress. I have also created a board layout for my circuit. I am posting both here to see what everyone thinks of the redesign using Eagle.
| I need help in designing a circuit | chefach | Electronic Projects Design/Ideas/Reviews | 13 | 27th September 2007 11:14 AM |
| power electronics circuit analysis | ptewright | Electronic Projects Design/Ideas/Reviews | 2 | 25th November 2006 08:16 AM |
| Circuit auto OFF feature after no events design | Uman | Electronic Projects Design/Ideas/Reviews | 2 | 3rd May 2004 05:34 AM |
| HELP! a digital signal to close a circuit | fireismyflag | Electronic Projects Design/Ideas/Reviews | 2 | 22nd March 2004 10:45 PM |
| Circuit functioning very strange. Why? | Cyclone | Electronic Projects Design/Ideas/Reviews | 12 | 4th November 2003 12:30 AM |
