| I found a simple hall effect application. Is that what I could use to control the PC soundcard's stereo output volume via a DIY breath controller to add tremolo and/or volume changes? ![]() ![]() Not quite sure how it works. As far I discovered it works with moving a little magnet to the hall effect sensor or visa versa. How do I connect the soundcard's outputs to it? Finally, how to make it work logarithmically? Since I need only to control the soundcard's stereo output, I'm glad not to bother with MIDI control and that surely makes it less problematic. | |
| for breath control maybe you should look at something that is temperature sensitive. A Thermistor is a temperature variable resistor and may suit your needs better. | |
| My use of hall effect sensors have been for measurement of revolutions .When a magnet is passed by the sensor a pulse is emitted . Those pulses are cleaned up and passed to a counter circuit and then to a display which when calibrated then gives the rpm How were you thinking of using these sensors ? Look to the bottom of this screen for similar threads .There are quite a few
__________________ I Hate Microsoft-the site below says it well http://www.vanwensveen.nl/rants/micr...eMS_intro.html Last edited by tytower; 10th January 2008 at 10:04 AM. | |
| Hall Effect Sensor | gramo | Micro Controllers | 14 | 21st April 2007 01:49 PM |
| What type of Hall Effect sensor is cheap and common? for rotation sensor with magnet. | William At MyBlueRoom | Electronic Projects Design/Ideas/Reviews | 2 | 30th November 2006 07:59 AM |
| Hall Effect Sensor | bryan1 | General Electronics Chat | 1 | 16th September 2005 09:21 AM |
| hall effect sensor | koyeh182 | Electronic Projects Design/Ideas/Reviews | 5 | 26th December 2003 03:12 AM |
| Hall Effect Sensor Question... PWM too... | iso9001 | General Electronics Chat | 11 | 15th December 2003 03:40 AM |
