Old 8th January 2008, 05:09 PM   (permalink)
Default Building Small Death Machine
I need to use a 12VDC 2 amp motor to carry the weight of my fabrication. The problem is I'm using a 9 volt battery and remote control car circuitry to power it. I've devised a circuit that I believe should work, but I'm not happy with it. For one, Ive used two twelve volt batteries. Second, my diode positioning doesn't seem right even though it seems to work when I follow it.
I'm new to electronics. My only exposure to the topic is a Naval training course which is not by any means helpful.
I would either like someone to confirm that it works, or possibly show me a much better concept.
My circuit is set up like this because the motor needs the ability to turn the output shaft forward or in reverse, and I can't use twelve volts in the RC circuit because it will fry.
Schematic:
Hopefully it worked.
€€€! It's like ¥¥¥, but way better!
FCSN_Man_of_the_year is offline
Old 9th January 2008, 02:22 AM   (permalink)
your circuit may not work because led ,there's better circuit than this using single battery.
this circuit may work, but no stop
Publish your web page
jumides is offline
Old 9th January 2008, 03:24 AM   (permalink)
use a double pole relay, and put the led on one set of poles and the motor on the other
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 9th January 2008, 03:39 AM   (permalink)
Hi FCSN_Man_of_the_year,
You could do it with one battery if your relays had two "make"
contacts, but I assume they haven't because you would have
designed your circuit accordingly.
The led's aren't designed to carry two amps and they aren't so
happy with "large" reverse voltages. Select a series resistor of
approx. 1K to limit the current through the led's.
on1aag.
on1aag is offline
Old 12th January 2008, 01:48 PM   (permalink)
That would work but I don't see why you don't use a single 12V supply and a full h-bridge.
Screen name: Aloone_Jonez
Hero999 is offline
A small wind power project Green_NRG Alternative Energy 6 29th November 2007 11:14 PM
Building a very simple IR-Switch with kids: Help needed Schorhr Electronic Projects Design/Ideas/Reviews 23 16th March 2007 03:24 PM
Transmitting small voltages aibelectronics Electronic Projects Design/Ideas/Reviews 8 24th May 2006 06:11 PM
need help building a coin sorting machine pcgui2001 Electronic Projects Design/Ideas/Reviews 7 19th January 2004 11:20 PM
Small display rik Datasheet/Parts Requests 3 23rd September 2003 10:56 PM
