Old 8th January 2008, 08:24 AM   (permalink)
Default Digital temperature display
This will be one of my first projects.
The Temperature sensor I plan/planned to use is the LM35 - Precision Centigrade temp sensor.
http://www.national.com/mpf/LM/LM35.html
Would it be best to use a analog sensor or a digital sensor? Does anyone have a schematic for some thing like this, with a LCD, the temp. sensor and micro-controller?
What micro-controller would you recommend for something like this?
Sgrios is offline
Old 8th January 2008, 10:56 AM   (permalink)
You can use either. If you are only doing one sensor then both work about the same for you.
If you use the analog part you need to understand how to do the analog to digital conversion on the micro controller.
If you use the digital part you need to understand the communication protocol that the part uses.
Both are fairly simple. If you goggle you should be able to find several examples of each.
We most often use PICs here but most any modern uC will be OK.
3v0 is online now
Old 8th January 2008, 01:23 PM   (permalink)
of course, u dont have to use a uC, u could try an analogue to digital display convertor. maxim, intersil and whatnot have these parts for free samples, so you could give it a go. Although, u need LED displays and i haven't had much luck with them in the past. Just a suggestion.
BTW: the suggested schematic is on the datasheet.
-michael11298
mike11298 is offline
Old 8th January 2008, 01:28 PM   (permalink)
Try LM75 which is said to have digital output.
Regards,
Sarma.
mvs sarma is offline
Old 8th January 2008, 02:06 PM   (permalink)
The schematic for this thermostat is on my site (Cricket)
Bill
Smart Kits build Smart People
Old 9th January 2008, 04:18 AM   (permalink)
132 !! I think you need an air conditioner
bryan is offline
Old 9th January 2008, 04:35 AM   (permalink)
Lol actually it's the sensor A/D reading raw in hex with a 2.5V vref.
Bill
Old 9th January 2008, 03:08 PM   (permalink)
Those sensors put out a millivolt per degree. If you don't need to read over 200 look at the pre-built digital panel meters based on the 7107/7106 chip (one is LCD one is LED, I can never remember which is which). You can find many versions on eBay for under $15 USD. You can scale the input if you need over 200, but the native full scale of the 7107/7106 is 199.9 millivolts.
RDL2004 is offline
Old 9th January 2008, 03:24 PM   (permalink)
I think that it is 10mV/°C
Pommie is offline
Old 10th January 2008, 07:15 AM   (permalink)
Hello all
Well I have worked on this project. I used a 0804 A/D converter and seven segments. It was a weekly project of my Microprocessor Interfacing lab. Although i used a AT89C51 but I realized that there was no such need of Such a big microcontroller. Now when I am familiar with PICs I think a small pic with would be enough Rather I recommended using Pic for this project.
Although I have not worked on PICs but I have heard some pics have built in A/D converter, if this is true then i think all You need is a PIC LM35 and a Display
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 10th January 2008, 08:08 AM   (permalink)
Originally Posted by Cry_Wolf
Hello all
nowadays, even the ADC can be done by the same processor and perhaps we can avoid the ADC even. These specs of what elements to use are given to students, in order to train them to be able to write proper software, in case if micros and realise and sort hardware issues in case of ICs like 7106(7).
Regards,
Sarma.
Old 10th January 2008, 04:38 PM   (permalink)
Yes, I was remembering wrong. It's 10mV per degree (the LM34 is degrees F). So you would maybe have to use a resistor voltage divider. It depends on what temperature range you need to measure.
RDL2004 is offline
Old 10th January 2008, 11:08 PM   (permalink)
0 - 100 `C range the Vref for 0804 will be 2.5 volts. For that you need a POT and a zener diode
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 10:15 AM
The Oscilloscope ElectroMaster Electronic Theory 12 3rd February 2008 02:45 PM
calculator chinmay7 Micro Controllers 1 14th October 2007 01:45 PM
digital display for magnetic field PratapKollu Electronic Projects Design/Ideas/Reviews 7 13th March 2007 02:19 AM
microchip application A590 /display is ok now prosound90 Micro Controllers 20 18th November 2006 10:44 PM
