Old 8th January 2008, 07:08 PM   (permalink)
Just use an 47 ohm resistor. It is close enough, then the Tolerance should help out too.
Krumlink is offline
Old 11th January 2008, 07:23 AM   (permalink)
Smile
Thank you very much. My teacher has approved the circuit diagram and now I will implement it.
Affan is offline
Old 11th January 2008, 07:33 AM   (permalink)
Originally Posted by Affan
Can we somehow use a larger resistor to make the project? Because resistor of this resistance(R<50ohm) are rare here.
I guess you are in Pakistan
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 12th January 2008, 05:03 PM   (permalink)
Exactly Sir! I am from Rawalpindi, Pakistan. One more question sir. Which one among LM338K and LM340 would be better to implement this 2A dc current source project and why?
Affan is offline
Old 12th January 2008, 05:29 PM   (permalink)
Krumlink, you should add a smiley when you're joking. I'm afraid our OP took your advice seriously.
Ron (aka Rube)
Roff is offline
Old 12th January 2008, 05:35 PM   (permalink)
You need to do some of your homework yourself. Draw schematics of 2 amp regulators using both parts, and calculate the power dissipation of the required resistor. You should be able to deduce the answers to your questions from these calculations.
Ron (aka Rube)
Roff is offline
Old 12th January 2008, 05:37 PM   (permalink)
This may or may not be of interest:
http://web.archive.org/web/200611282...fo/d-pscc.html
it is a really simple adjustable 5a constant current power supply.
I've built a few for bench testing high power leds. The one I use the most is based on National's LM1084 ldo regulator, and I have the peak current limited to about 1.1a using a pair of 2.2ohm resistors in series.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 13th January 2008, 10:47 AM   (permalink)
Question
Sir please tell me about it (LM338K or LM340 and why?). Even if power dissipation is the only factor then which one will be better. And also if there is any other factor.
Affan is offline
Old 13th January 2008, 12:35 PM   (permalink)
I think if you consider the power dissipation in mind ,LM338K is the one best for you.
Other factors depends upon the application in which you wanna use it.
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 13th January 2008, 12:53 PM   (permalink)
I think if I asked my lecturer for approval of a circuit diagram just two days before the finished article was due to be handed in, he'd laugh openly at me and tell me to come back next year!
Good luck with your project, I hope it works out
Brian
Brian Hoskins is offline
Old 13th January 2008, 05:16 PM   (permalink)
For a given supply voltage, the 338 will have higher voltage compliance on the output than the 340. In other words, the 338 can handle a higher resistance load than the 340.
Ron (aka Rube)
Roff is offline
Old 4th May 2008, 01:38 PM   (permalink)
Smile
Brian
2 Days was the time for finalizing the circuit and get it approved by the teacher. Implementation was to be started after that.
Affan is offline
Current source GagoX Electronic Projects Design/Ideas/Reviews 13 12th January 2008 07:32 PM
LM 317T Constant current charging problem Suraj143 General Electronics Chat 11 4th June 2007 07:22 PM
Current and Conductivity ElectroMaster Electronic Theory 1 2nd February 2007 01:50 PM
programmable current source from a microcontroller bajgik General Electronics Chat 11 30th April 2006 11:49 AM
constant current sources walters General Electronics Chat 7 21st August 2005 07:46 PM
