Old 7th January 2008, 02:45 AM   (permalink)
Default can sombody review and coment my design
hello
i am not a designer but i have my experiance in repairing stuff and hobbying
i design this to swich 2 transfer pumps that work on fixed time alternating
design criterias are keep it simple cheap and foolproof
an other problem i have here in cambodia is that components are very hard to get by
as you can see in the shematic i made an analoge AND port with 4 inputs
normaly i would use the 4082 but is not availible here
i prefer to use triacs because 220V contactor blocks are the only one that are on the shelf here otherwise 24V i have to order them and wait 4 weeks to get them, not good if one break down and you have to replace them right away
thanks in advance
Robert-Jan
rjvh is offline
Old 7th January 2008, 08:52 AM   (permalink)
I am having problems opening your pdf.
Anyone else been succesful?
EDIT:
Had to download an extension to my Foxit pdf reader.. now OK.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 7th January 2008, 09:12 AM   (permalink)
hi Robert-Jan,
Looking at the circuit, it has a number of serious errors and omissions.
For example:
the zener diode has no current limiting resistor.
the mains transformer is connected so that you have no isolation.
[the Neutral phase is connected to the 0V/common line]
etc.....
The right side of the drawing is cut off?
EDIT:
Are opto-isolators available in your region??
Eric
PIC tutorials:
Old 7th January 2008, 09:33 AM   (permalink)
didn't came across a oupto coupler yet in cambodia
bangkok is the closest place to get them but that trip i make only 2 times a year
the reason the nuetral is conected to the 0V line is to get the triacs working
right side of the drawing is only the capacitor + resistor to protect the voltage spikes over the triac
the whole PCB and its conections will be in a IP 53 housing in the swich panel what also is rated for IP 55
rjvh is offline
Old 8th January 2008, 01:29 AM   (permalink)
did made some changes regarding the current limiting resistor
i could made some changes in the contactors (24Volt ones ) so i don't have to use triac and i could go for a FET (IRF 510) and change the whole power suply to 24V dc
the thing is that the contacters will cuase problems over a timespan of 2 years due to the agrasive envoirment they are placed in
troppics ,high humidity pump room , and chlorine fumes (swimming pool pumps)
and a sudden brakedown of a contactor have to be tackeled by replacing it imedietly and preferbly the other ones in the panel also
220V in store 24V lead time of 4 weeks
rjvh is offline
