| Hi everyone. I´m making this thread because i want to ask anyone for help/knowledge. I´ll try to explain what i want. I´m trying to make something like (shift gear light) but diferent, and the difference is that i have a 7 segments that indicates the gear that i´m in the moment ex: (1,2,R,N.etc...). I´ve found in the web something like this but it only had one switch and i need a schematic that has at least 8 switchs for (1,2,3,4,5,N,R,P) first gear, second gear, third, fourth, fifth, Neutral, Rear and finally Parking. I do not no programing and don´t have the tools to do it. I´ve uploaded the same image here to that will help explain on what i really want. http://img178.imageshack.us/my.php?i...rprojechl2.jpg If anyone understand my explanation or need some details info or thinks it has a better way to do the same exact thing please tell me i would like to know. Best regards to everyone and thanks in advance Last edited by Griever; 5th January 2008 at 04:54 PM. | |
| As you know this is s 7 segment display. It has segements A,B,C.D,E,F and G. Which segments are lit up to display N and R ?
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | |
| You could do it with just a bunch on 1N4148 diodes (Matrix) and seven current limiting resistors. | |
Standard way to do it really!. | ||
alphanumeric-led-font.jpg But since i can´t find any to buy(if you know any online store that sells them and ships them to Europe EVEN BETTER), i´ll use a 7 segment and for the N and R i was thinking in some kinda simbol like this.. This for the Neutral: Neutral gear simbol for Shift gear light.JPG This for the Reverse(If you notice its the way you have to move the gear knob to put the reverse): Reverse gear simbol for Shift gear light.JPG For anyone thinking that the only thing i did was the concept of the project.. I already made a circuit using OR, AND,XOR Gates i made it first on EWB(If anyone wants the file i can post it here). In the EWB it worked really well just as i wanted but then i made the circuit on a Breadboard and when i was about to test it i noticed that it worked as well but with something really weird. As i remember for example a OR gate when one of the In´s is at 1 satge(in my circuit 5v) at the Out of the gate we should have 1 as well(5v) but when i put both the In´s at 0 stage (0v), in the Out i have 2v ALWAYS in every OR gate. Result: all LED´s in the 7 segment are turned on but when i simulate a gear actuating the Switch (for example the first gear) it slightly increases the brightness. It looks like this: Picture 4.JPG If i wasn´t clear enough just tell me i´ll be glade to clarify any question. Best regards | ||
And other thing you don´t know why the Gates even when the out should be 0 (0v) it gives me 2v?? | ||
| | (permalink) | ||
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | ||
I´m using a 7 segments with CA. To drive it i´m using 5v with the 7805L regulator but if needed i also have LM1084IT-12 (12v regulator) the IC i made works fine but has that problem i mencioned. It uses 30 OR gates 5 XOR gates and 2 AND gates and finally 8 NO switchs. If you can make a more simple circuit that does the same thing i´ll be very grateful.
__________________ Just someone trying to learn | ||
So for number '1' which only uses two segments, you require only two diodes, but for number '8' you would require 7 diodes. So no IC's at all, just a bunch of diodes and seven resistors (one for each segment). Your current solution is some what over engineered! | ||
| OK, here's a partial circuit, showing how to do the digits 0 and 1. | |
| A lot of auto gearboxes have a selector switch already on the top of the gearbox for the autobox ecu to know which position is selected. I'd personally use that to get the signal to find out which gear is selected. | |
| Nigel and I are thinking alike, mine show digits one and four.
For those of you who remember PC cases with digital 'speed' displays on the front?, those were simply wired in that same way - merely showing the position of the 'Turbo' switch, not actually measuring anything. | ||
| need schematic urgently | ycxxi | Datasheet/Parts Requests | 5 | 3rd December 2007 07:32 PM |
| 7 segment display and user inputs displayed | trickae | Electronic Projects Design/Ideas/Reviews | 5 | 9th August 2007 09:15 PM |
| driving multiplexed 7 segment display | mathur2000 | Micro Controllers | 7 | 24th June 2007 11:08 PM |
| Charlieplexed code segment for the Cricket Thermostat | William At MyBlueRoom | Micro Controllers | 2 | 14th March 2006 05:12 PM |
| newbie needs help with presetable count down timer 7 segment | zenton | Electronic Projects Design/Ideas/Reviews | 3 | 6th September 2004 05:16 AM |
