Old 3rd January 2008, 10:22 AM   (permalink)
Default Replacement for BAT82 diode ?
Hi guys,
I was wondering, with so many of you here experienced in electronic projects, if anyone knows of a suitable replacement for a BAT82 schottky diode? I am supposed to use that diode but I cannot find it in any of the shops.
I figure I would ask here first in case any of you are familiar with it. If not then I will have to match the specs with other similar diodes myself.
The datasheet,
http://www.ortodoxism.ro/datasheets/...81_82_83_2.pdf
I am using it in a lead acid charger circuit. Thanks.
rngd is offline
Old 3rd January 2008, 11:24 AM   (permalink)
Originally Posted by rngd
Hi guys,
The datasheet,
You can confidently use 1N5817,18,19 . data sheet at
http://www.onsemi.com/pub/Collateral/1N5817-D.PDF
Regards,
Sarma.
mvs sarma is offline
Old 5th January 2008, 07:35 PM   (permalink)
OK thanks Sarma. I will check if the shops have this.
rngd is offline
Old 5th January 2008, 10:07 PM   (permalink)
I don't know how you can be confident without knowing the application. Your suggested replacement has about 10,000 times the leakage current and as much as 100 times the capacitance of the BAT81 series.
I think rngd needs to tell us how the part is used.
Ron (aka Rube)
Roff is offline
Old 6th January 2008, 05:50 AM   (permalink)
Yes. I should have suggested a better device- but the O P has indicated its use--
"I am using it in a lead acid charger circuit."
Thanks for the suggestion that helps me to be more critical in future.
Regards,
Sarma.
Old 6th January 2008, 05:55 AM   (permalink)
A thousand pardons. I totally missed the application information. I guess I really am getting old.
In fact, the BAT81 series would be unuseable unless the usage is in a trickle charger for a small lead-acid battery.
Ron (aka Rube)
Roff is offline
Old 6th January 2008, 06:22 AM   (permalink)
Please -- you are perfectly correct NOT about what you felt in this post- and i could have chosen a better device irrespective of the actual use. when suggesting an equivalent, i should be careful. this is because, the O P may generalise this advise and try applying tomorrow at some RF application for band switching. you are correct and need not be apologetic. in fact I should feel for it. All the best of 2008 Please.
Regards,
Sarma.
Old 6th January 2008, 12:46 PM   (permalink)
Quite right, he said it's for a lead acid charger but he didn't say what type, if it's a switch mode power supply the diode you suggested probably won't work.
Screen name: Aloone_Jonez
Hero999 is offline
Old 6th January 2008, 01:36 PM   (permalink)
Glad you guys cleared your misunderstanding. The charger is a trickle charger charged by a solar panel. So the 1N5819 diode can be used, right ? The circuit is attached below just in case. It is designed by someone named Oscar.
ps. I have a quick newbie question, what is the difference between the two MOSFET symbols in the second attachment ?
Thanks !
rngd is offline
Old 6th January 2008, 01:43 PM   (permalink)
Thanks !
The two BAT diodes are just to clamp the input to the op amp to about +/-0.4V.
The two MOSFETs are the same type, ref drawing, just drawn that way for convenience..
The 'arrows' direction on the FET's indicate a different type.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 6th January 2008, 03:17 PM   (permalink)
I would also connect one of the inputs of the unused comparator to +15V and the other to 0V.
Hero999 is offline
Old 8th January 2008, 10:00 AM   (permalink)
OK, thanks for the help.
rngd is offline
Old 8th January 2008, 10:22 PM   (permalink)
There is an object lesson here. The lesson is, most noobs post too little info, rather than too much. If you had posted the schematic in the first place, we would have told you to use 1N4148's. The 1N5917 is one of the poorer choices for this application, although it should work.
Ron (aka Rube)
Roff is offline
Using a MOSFET as a diode replacement? blueroomelectronics General Electronics Chat 12 1st September 2007 02:57 PM
Replacement of HV Diode sujit_51 Datasheet/Parts Requests 0 11th March 2005 04:32 AM
surface mount replacement for 1n4004 diode ? themikestar Datasheet/Parts Requests 2 2nd January 2004 10:19 PM
Here is a list of semiconductor prefixes. TPS Datasheet/Parts Requests 0 21st December 2003 08:24 PM
Identify Semiconductors by prefixes mixos Datasheet/Parts Requests 0 10th December 2003 07:56 PM
