| I found this schemmy of a Ring Oscilliator, and I was wondering if it was possible to replace the 2N7000's with a 2N2907 or a 2N2222. I know this is a useful circuit, and I would like to build it, but could I replace them? Thanks. | |
| hi Krumlink,,, HNY.. As you know, the 2N7000 is a FET and 2N2222 bipolar, so afraid the answer is no...
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ | |
| I did not get the box into the mail on new years eve. I just tossed an 2n7000 into the bag along with the parts for the new target board. It has cardboard on the leads, the regulator does not. | |
| Ok thanks 3v0. I will look online for a Bipolar Ring Oscilliator. Hopefully Semiconductor theory will not screw me over | |
| Noooooooo Semiconductor Screwed me over If anybody knows of how to make one using Bipolar Transistors, Let meh know! | |
| A ring counter would make a good project using a microcontroller... | |
| I know, but with my programming computer STILL gone, no it wouldnt be | |
| why do you need a bjt? Are you searching for a specific Beta? | |
| Quix what are you talking about??? What if I built it with Bipolar Transistors? | |
Depedning on how much outut voltage/current you want, depends lagely on the betas. Thats why i'm asking why do you want to use the bjt's. Are you tring to reach some specific gain or output level? | ||
The computer is only 3 days away, unless that has changed. It would be easy to create a similar device in software and watch the bits change on the port. Actualy you already know how to do that (at least fake it) if you think about it. If you are looking for somthing to do I can send you some C related material to study. | ||
| Depending on the frequency you want you can use a single inverter, an R and a C to make a relaxation oscillator. You can also use an od number of inverters to make a ring oscillator whose frequency will be a sensitive function of Vcc, temperature, and the propagation delay of the particular gate you select. Combining these two concepts you should be able to amuse yourself for a very long time. | |
Papabravo: I will look around. I am working on a 555 pummer I designed, so I will get back to this later. | ||
| Replace mouse encoder? | xkrja | General Electronics Chat | 14 | 26th August 2006 04:15 AM |
| pchannel version of 2N7000 ? | William At MyBlueRoom | General Electronics Chat | 3 | 27th May 2006 12:35 PM |
| 2N7000 does this work? (in a common anode display) | William At MyBlueRoom | General Electronics Chat | 16 | 24th April 2006 08:13 PM |
| Replace a phototransistor | emusky | Datasheet/Parts Requests | 2 | 2nd August 2003 05:42 AM |
| *Edit, OOPS!* can i replace this transistor? | daviddoria | General Electronics Chat | 12 | 15th February 2003 07:57 PM |
