Electronic Projects Design/Ideas/Reviews Are you building an electronic project or want to? Maybe you need some assistance? Come and submit your electronic questions here and let our exprienced members find a solution.
Thread Tools Search this Thread Display Modes
Old 1st January 2008, 04:19 PM
Experienced Member
Hayrettin Demir is on a distinguished road
Default Basic , with Relay's Code Circuit Diagram...
Basic , however effectual a Circuit Diagram.
Edit:English translation in Circuit.
Hayrettin Demir is offline   Reply With Quote
Old 1st January 2008, 04:25 PM
Super Moderator
Why are you posting random pointless diagrams?.
Old 1st January 2008, 05:08 PM
Experienced Member
Yes.Sorry...
I translate in English this Shema.
Old 1st January 2008, 09:12 PM
Experienced Member
ljcox is a jewel in the roughljcox is a jewel in the rough
I'm not sure why you posted this circuit.
It seems more complex than is necessary. For example, R12 is not required.
I suspect that it could be done with less relays.
Attached is an electronic one that I designed some years ago.
L is the door solenoid.
The counter is advanced each time the correct button is pressed. If the wrong button is pressed, the counter is reset.
Len
ljcox is offline   Reply With Quote
Old 2nd January 2008, 02:41 AM
Experienced Member
Here is how I would do it with relays.
Len
Old 2nd January 2008, 06:46 PM
Experienced Member
You design have more nakeds.
So my shema have very very traps.
Example that have Total Operation Time , and more Turn On and Turn Off Circuits.Thats important.
Yes , R12 is extra.
And this topic name is "Basic , with Relay's Code Circuit Diagram... ".
Also with not other Electronic Component.(IC , PIC , or microProcessor).
I am sorry my friends...
For my English.
Old 2nd January 2008, 08:43 PM
Experienced Member
Default Please Check , ERROR ...
For my English.
Old 2nd January 2008, 08:56 PM
Experienced Member
...I don't understand what you mean by "nakeds". I think you mean weaknesses.
So my shema have very very traps. I don't know what you mean by "traps". I think you mean that your circuit includes several techniques to make it difficult for someone to open the door without knowing the code.
Example that have Total Operation Time , and more Turn On and Turn Off Circuits.Thats important. I don't understand "Turn On and Turn Off Circuits". I think you mean delay circuits.
Yes , R12 is extra.
I think you mean that you want to do it with relays, not with electronics.
The "total operation time" in my circuit is done by R1 & C1 & Q2. The timing starts if X1, X2 or X3 are operated. I noticed that your circuit has a delay in the operation of the Door Solenoid. I do not think that is necessary, but this may be one of your "traps" intended to make it difficult to circumvent the system. Such a delay could be added to my circuit if necessary.
Len
Old 2nd January 2008, 09:00 PM
Experienced Member
Yes, your point about the invalid buttons is a good one.
In my first design, I had an extra relay labelled E (for error) that operated if an invalid button was pressed. But I felt it was unnecessary, so I removed it and made double use of X4.
However, this leads to the problem you have mentioned.
Here is my first design.
Len
Old 2nd January 2008, 09:36 PM
Experienced Member
nakeds is exposed...
Ok...I explain later.
Ok...
So , please see your in shema error.
For my English.
Old 2nd January 2008, 09:41 PM
Experienced Member
Ok...
What error?
Note that I have just edited my previous post as there was a minor error in the circuit. (D4 should have been D5)
You responded to this post while I was editing it. So you have not read some of my comments,
Len
Old 2nd January 2008, 11:26 PM
Experienced Member
Yes.
Yes.
But some errors is ;
For my English.
Old 3rd January 2008, 02:26 AM
Experienced Member
I don't see what the problem is.
Your "Error connect" drawing is not correct. DS is not operated directly by B4.
X4 operates when B4 is pressed. DS operates when X4 operates, ie. B4 AND X4 must be operated to operate DS..
When B4 is released, both X4 and DS release.
This is exactly what I intended.
I have made a minor improvement to my circuit.
I have changed it so that if B2 or B3 is pressed out of sequence, relay E operates and releases any X relay that is operated.
Len
Old 3rd January 2008, 07:31 AM
Experienced Member
Default No , please again check...
For my English.
Old 3rd January 2008, 08:41 AM
Experienced Member
Answers and questions in response to your points:-
1. I'm not sure what you mean. Do you mean that the N/O contact opens 2 ~ 5 ms after the coil circuit is opened, ie. the relay release time? Why is this an issue?
Also, remember that the diode across the coil will increase the release time.
2. X3 is supposed to release when X4 operates.
3, 4. Yes, the current through the X4 contact is Ir + Ids. That is how it is meant to be.Why is this an issue?
I explained how it works in my previous post, ie. X4 operates when B4 is pressed. DS operates when X4 operates, ie. B4 AND X4 must be operated to operate DS.
Hence, X4 and DS both release when B4 is released and the circuit returns to its initial state.
Len
Search this Thread:
Advanced Search
Help with basic voltage reducing circuit for auto Terry335 Electronic Projects Design/Ideas/Reviews 4 21st May 2007 08:55 PM
ADC circuit.. program code ecy61mrh General Electronics Chat 2 15th March 2007 07:41 AM
basic circuit help efiste2 Electronic Projects Design/Ideas/Reviews 3 30th January 2007 04:16 PM
electronic earth leakage circuit breaker circuit diagram jideadido General Electronics Chat 0 1st June 2004 07:50 PM
Basic Serial Port Circuit grudge Electronic Projects Design/Ideas/Reviews 4 18th April 2003 12:04 PM
Powered by vBulletin Version 3.5.4
Search Engine Friendly URLs by vBSEO 2.4.0
