| Experienced Member | Quote:
See attachment.
__________________ Len | |
__________________ I am sorry my friends... For my English. |
| Experienced Member | This is wrong. Look at the circuit I posted.
| Experienced Member | Here is an extract from my circuit. Your circuit is different. See my corrected version.
__________________ Len Last edited by ljcox; 10th January 2008 at 08:29 PM. |
__________________ I am sorry my friends... For my English. Last edited by Hayrettin Demir; 10th January 2008 at 10:07 PM. |
| Experienced Member | No! As I told you in an earlier post, the current decays from 20 mA. The simulations I attached earlier are attached here again. The simulations show that the release time is a little longer without the diode. So why include a diode? By the way, your relay contact is transposed. The N/C contact should be connected to the negative side of the battery and the N/O contact should go to the coil.
__________________ Len Last edited by ljcox; 11th January 2008 at 05:18 AM. |
| Experienced Member | hi Hayrettin Demir, I have been reading and following the posts for this thread. It looks as though you are not reading the EDIT's that Len is posting when he answers your questions. I understand there is a language problem, BUT it is important that you read his replies carefully and answer his questions, so that he can help and guide you. Regards..
__________________ Eric "Good enough is Perfect" PIC tutorials: Nigel's: www.winpicprog.co.uk/ Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ |
| Experienced Member | Thanks for the input Eric. The op clearly does not understand inductance.
| Experienced Member | Your timing diagram is not quite right. See the attachment. Relay X1 holds via diode D5 until B2 is released. Relay X2 holds via diode D7 until B3 is released. This is necessary because X2 opens the holding path of X1. So the X2 contact must hold itself before X1 releases, otherwise X2 might release when X1 releases. It depends on the operate time of X2 and the release time of X1. I assume that X5 is a new relay. You will need it to do what you have shown in the diagram. I will leave it to you to work out how to do it. Let me know if you need help. I would make X4 slow release like RS and use RS to operate DS. X5 could release X3 and start the release of X4.
| Experienced Member | Yes... B2 --> on D5 continue --> X1 , B3 --> on D7 continue --> X2 .
| Experienced Member | Here is how I would do it. EDIT. I replaced the Sequence chart attachment as there was a minor error in the t2/t3 area. EDIT 2. Replaced circuit - last sentence was wrong.
__________________ Len Last edited by ljcox; 16th January 2008 at 06:55 AM. |
| Experienced Member | This is seem excellent.
| Help with basic voltage reducing circuit for auto | Terry335 | Electronic Projects Design/Ideas/Reviews | 4 | 21st May 2007 08:55 PM |
| ADC circuit.. program code | ecy61mrh | General Electronics Chat | 2 | 15th March 2007 07:41 AM |
| basic circuit help | efiste2 | Electronic Projects Design/Ideas/Reviews | 3 | 30th January 2007 04:15 PM |
| electronic earth leakage circuit breaker circuit diagram | jideadido | General Electronics Chat | 0 | 1st June 2004 07:50 PM |
| Basic Serial Port Circuit | grudge | Electronic Projects Design/Ideas/Reviews | 4 | 18th April 2003 12:03 PM |
