Old 3rd January 2008, 06:22 PM   (permalink)
Experienced Member
Hayrettin Demir is on a distinguished road
3, 4. Yes, the current through the X4 and B4 contact is Ir +
Ids.
Why is this an issue?
Because this is issue and more.
Also DS from where negativ to pass ? (Answer : B4)
DS's in circuit 1A or more Current to pass.
1A current is for push-buton or to be too much.
I am sorry my friends...
For my English.
Hayrettin Demir is offline   Reply With Quote
Old 3rd January 2008, 09:23 PM   (permalink)
Experienced Member
ljcox is a jewel in the roughljcox is a jewel in the rough
Now I understand.
The coil current of DS is too much for the B4 contacts.
Here is a simple solution and it has the additional advantage that D5 is not required.
Len
ljcox is offline   Reply With Quote
Old 4th January 2008, 04:30 PM   (permalink)
Experienced Member
Originally Posted by ljcox
Now I understand.
Yes...Now DS-B4 problem is OK...
For my English.
Old 4th January 2008, 08:38 PM   (permalink)
Experienced Member
That's good.
It is possible to include B1 and B4 in the error logic.
It will require the following extra components:- 1 relay, 3 diodes, 2 capacitors & 2 resistors.
The resistors and capacitors are necessary to increase the release time of relays X4 and E by a small amount.
This necessary to ensure that any operated relays (ie. X1, X2 or X3) will release before X4 or E release.
I'll leave it to you to work out how to do this - if you wish.
Let me know if you want to see my method and I'll post it for you.
Len
Old 5th January 2008, 02:25 PM   (permalink)
Experienced Member
Firstly , Error Relay Coil parallel appr. 4700uF Condensator required.
For my English.
Old 5th January 2008, 08:12 PM   (permalink)
Experienced Member
Why do you need a capacitor that large?
What is the resistance of the relay coil?
Len
Old 5th January 2008, 10:50 PM   (permalink)
Experienced Member
If any Error Buttons press.For this is delay time required...
(appr.2200-4700uF--> For 5sn (appr.) delay time to get).
For my English.
Old 6th January 2008, 02:31 AM   (permalink)
Experienced Member
Here is the circuit with additional error logic so that circuit will be reset if B1 or B4 are pressed out of sequence.
I have changed the name of relay E to RS as it now does a reset function even when the correct sequence of buttons is pressed.
The release time of RS (determined by C2) allows time for the release of any operated relays.
Len
Old 6th January 2008, 03:27 AM   (permalink)
Experienced Member
Leftyretro has a spectacular aura about
What a mess relay logic can quickly become. I was always amazed that the telephone companies switching relay logic worked as well as it did. Seems to me I read an early 'computer' was built using relay logic during or right after WW2.
Relays are still very useful. They have great isolation (input/output) and can be sized for crazy voltages and current levels. So they are still very viable as a final control element, but as a logic solver?
Get real, a simple micro-controller driving the door solenoid via a Mosfet is so much simpler, better, cheaper and programmable that it's painful to even have to explain.
Lefty
Measurement changes behavior
Leftyretro is offline   Reply With Quote
Old 6th January 2008, 08:51 AM   (permalink)
Experienced Member
You're overlooking one distinct advantage relay logic has over electronic logic.
In its quiescent state, it consumes ZERO energy. Therefore it could be run from a battery that would only have to be replaced every 2 ~ 3 years.
How long would an electronic one run on a battery?
The CMOS one I posted above may last quite while (as it is a combinational lock, there is no oscillator running or other power consuming items), but I'm not too sure about a PIC version.
Besides, the op specified a relay version - I don't know why - perhaps it is a school project.
The first "computer" - the Colossos - was built in England during WW2 to assist in decoding German cyphers was partly electronic and partly relay logic.
Len
Old 6th January 2008, 01:18 PM   (permalink)
Experienced Member
Default 1N4007 required...
For my English.
Old 6th January 2008, 04:27 PM   (permalink)
Experienced Member
Ok...
Now identically for X4 Relays delay time required.(approx. 1-3sn)...
For my English.
Old 6th January 2008, 04:36 PM   (permalink)
Super Moderator
And was then dismantled and the parts returned to the Post Office - an amazing story!.
Britain had a massive world lead in computers and all from a single guy who worked for the Post Office, and 'stole' all the parts to build it!
I'm sure I read somewhere a bit back that they have built a reconstruction of it now?.
Old 6th January 2008, 05:50 PM   (permalink)
Experienced Member
ericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud of
hi Nigel,
He [Tommy Flowers] actually spent a £1000 of his own money as well as the 'borrowed' bits to build the first one,
which after many years the Govt paid him back..
The other 9 Collososii were built with Govt funding.
Mr W Churchill at the end of the war ordered all the 10 to be dismantled and the documentation to be destroyed..
he was concerned it would fall into the hands of the USSR.
The working reconstruction was shown working on a recent TV program...
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 6th January 2008, 08:39 PM   (permalink)
Experienced Member
1N4007 required?
No
This is a standard technique used to increase the release time of relays.
But a diode is not used in that position as it is not necessary.
Len
Help with basic voltage reducing circuit for auto Terry335 Electronic Projects Design/Ideas/Reviews 4 21st May 2007 08:55 PM
ADC circuit.. program code ecy61mrh General Electronics Chat 2 15th March 2007 07:41 AM
basic circuit help efiste2 Electronic Projects Design/Ideas/Reviews 3 30th January 2007 04:15 PM
electronic earth leakage circuit breaker circuit diagram jideadido General Electronics Chat 0 1st June 2004 07:50 PM
Basic Serial Port Circuit grudge Electronic Projects Design/Ideas/Reviews 4 18th April 2003 12:03 PM
