| hiii... i have a design..that generate a sawtooth and a square wave...but i could not get any output when i simulate the circuit...anybody got some knowledge in Pspice to help? thanx | |
| make sure you have 1)enabled Transient Analysis 2)use the right final time
__________________ Steve Last edited by mister_e; 31st December 2007 at 10:22 AM. | |
Hope that helps, Torben | ||
thanx alot for your help...i iam just wondering if you can send me your schematic that u simmed | ||
Note: I've changed R1 and C1 just to get a lower frequency (bigger C1) and sharper sawtooth (R1). Decreasing R1 makes the sawtooth more like a sawtooth but also makes the pulse output shorter; making R1 larger will make the sawtooth look more like a triangle wave and the pulse output will look more like a square wave. [n.b.--I had to add a '.txt' extension to TL072.301 to make the forum software upload it; remove the '.txt' from the file name when you save it.] Hope this helps, Torben | ||
| If you decrease the value of R4, it will work on lower supply voltages (and raise the frequency). | |
I'd tried fiddling with that, but found (at least in the sim) that with supplies lower than +-15V, the thing would take several seconds to begin oscillating. I was at first using .tran 5, and with values of, say, 1k for R4 and rails of +-12V, it would appear to not start oscillating at all. Then I changed to .tran 25 and saw that it did oscillate, but not until almost 19 seconds. So I went with the original 100k for R4 and chose +-15V rails to ensure that even a short sim would show what's up. I am guessing that there is in fact a way to ensure that the circuit will start up properly without the +-15V rails--in fact, my results might just be a simulation error which I don't know enough yet to diagnose--but I haven't yet worked out what that might be and all my books are at home. I get home from vacation on the weekend so I'm stuck 'til then. I had actually thought about presenting the clever (well, I like it) circuit you presented in this thread but decided to let well enough alone since I don't stand a chance of being able to explain that one just yet. [Edit: another reason I skipped it is that it requires a sine wave as input and I had added a square wave out in my own simulation of it just to see if I could, so it's not really applicable here anyway. Oops.] Torben Last edited by Torben; 3rd January 2008 at 10:31 PM. | ||
| One way of getting it to start (usually, anyway) is to make the power supplies PWL sources. I tried it with a 1mS risetime - not so good. I changed it to 1uS and it worked pretty well. | |
Thanks for the tip! Torben | ||
| Multisim Simulation Speed Question | otacustes | Electronic Projects Design/Ideas/Reviews | 8 | 23rd March 2006 07:20 PM |
| Not sure: Simulation on software or to actual build it? | lowkb | General Electronics Chat | 6 | 10th August 2005 05:55 PM |
| PSPICE Simulation question | phalanx | General Electronics Chat | 1 | 8th June 2004 11:27 AM |
| Simulation help for project | hydro | Electronic Projects Design/Ideas/Reviews | 6 | 23rd December 2003 06:55 PM |
| Help --- Pspice Germainium Diode Simulation ((help)) | BABYBASS210 | General Electronics Chat | 2 | 26th May 2003 05:27 PM |
