Old 31st December 2007, 12:15 AM   (permalink)
Default measure resistance
Well I was searching for a good forum for Hobbyist. What read here is mostly over my head. Hopefully you fine members will help me out.
What I am looking for is a simple circuit that will measure resistance between 0 and 5k and display the amount on a small digital screen.
I usually buy my parts from Digikey.ca or Jameco.
Any help would be appreciated!!
dasatboy is offline
Old 31st December 2007, 12:34 AM   (permalink)
It's called a multimeter and can be purchased from all good electronics stores.
Screen name: Aloone_Jonez
Hero999 is offline
Old 31st December 2007, 12:37 AM   (permalink)
Sorry I should have been more secific. I am not really that stupid. I have more then one multimeter.
I want to built this circuit into another project I am working on!!
dasatboy is offline
Old 31st December 2007, 12:46 AM   (permalink)
EDIT: Oops, you wanted to measure resistance and not voltage. But pretty much the same thing still works- just use the resistance being measured as one of the resistors in theh resistive divider and the voltage measured will be proportional. YOu have to be able to apply a known voltage across the resisitive divider though.
dknguyen is offline
Old 31st December 2007, 01:04 AM   (permalink)
Two methods spring to mind.
Connect the resistor to a constant voltage source and measure the current.
Connect the resistor to a constant current source and measure the voltage,
You can get LCD pannel meters that display current or voltage and you can normally set the scale yourself.
Hero999 is offline
Old 31st December 2007, 01:08 AM   (permalink)
Here's an example of a complete meter in one IC plus display:
http://rocky.digikey.com/WebLib/NJR%...U9201B_02B.pdf
It may look complicated, but has lots of good features and won't take much work to implement.
RadioRon
RadioRon is offline
Old 31st December 2007, 02:42 AM   (permalink)
Sorry guys. I think I am in over my head. I can get 5v or 12v to the 5K pot but not sure how to make resistance show on a LCD screen yet. I will do some more reading!!!
dasatboy is offline
Old 31st December 2007, 03:04 AM   (permalink)
Ok so far I have figured out that I will need two resistors. One a constant resistance and the other the variable. power supplied to the resistors in parallel, the output of variable resistor to ground, measure the output voltage from constant resistor use formula to find the resistance of variable.
Now how do I get this to an LCD screen?
Now I am right thread. LOL
dasatboy is offline
Old 31st December 2007, 04:02 AM   (permalink)
use a A/D converter to measure the voltage, Once it is digital you can easily display it on your display
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 31st December 2007, 04:04 AM   (permalink)
I hope you know how to display some thing on the LCD.
Khizer Naeem Mughal
IIUI
Cry_Wolf is offline
Old 31st December 2007, 05:20 AM   (permalink)
sorry nope. Like I said over my head I think. It's actually the resistance I want shown on screen.
dasatboy is offline
Old 31st December 2007, 05:35 AM   (permalink)
Ok maybe some one can point me to some reading material I can get. Or Free-to-Web reading.
ThankX
dasatboy is offline
Old 31st December 2007, 01:51 PM   (permalink)
You can buy panel meters that display voltages between 0 and 10V, see Google for places where you can buy them from.
You can create a constant current source using an op-amp.
RL is your 0 to 5k variable resistor.
Rsc is a sense resistor.
Vref is a stable reference voltage.
I_{RL} = \frac{Vref}{Rsc}
In the example below.
Vref = 1V
Rsc = 1k
Therefore the current flowing through RL::
I_{RL} = \frac{1}{1000} = 0.001A = 1mA
Ohm's law states that V = IR which means that when the resistance is 5k 0.001 * 5000 = 5V so all you need to do is connect your panel meter's input across RL and (assuming it's input impedance is very high, >10M) you'll read 0 to 5V which corresponds to 0 to 5k for Rl.
To get V_ref I'd power the whole circuit of a 12V regulated supply and use a 2K 22k potential divider to get 1V.
Not that the op-amp needs to be able to accept input voltages down to 1V and output voltages down to 1V, an LM358 or MC33171 (I recommend the latter) will do fine. Also Rsc can be made smaller by adding another non-inverting gain stage or the output of the whole circuit can be amplified using a differential amplifier if needs must.
Hero999 is offline
Old 31st December 2007, 07:59 PM   (permalink)
Start here: http://www.electro-tech-online.com/m...d-upd-0xd.html
Nigel’s joystick tutorial uses R/C timing to measure resistance and displays on an LCD. If you can’t calibrate it to actual ohm value, at least it will be a real good start.
C:\WHUT ?
Beware the asterisk *
ClydeCrashKop is offline
Analog Meter windozeuser General Electronics Chat 19 3rd October 2007 03:44 PM
Measure resistance with a PIC PeterDove Micro Controllers 20 14th February 2007 03:58 PM
Input and Output Resistance Help andy257 General Electronics Chat 1 21st April 2004 02:35 PM
PIC 16F84a to measure resistance for switch positions 5neaker Micro Controllers 6 25th November 2003 06:32 PM
Real world test measurements? SomeoneKnows General Electronics Chat 8 26th August 2003 07:38 PM
