Experienced Member
Hi guys, I tried posting this in the other forums but a screen comes up saying I don't have the privleges or the admins blocked me or something.
So: I am working on a UHF small loop antenna. I want to model it as its equivalent square loop antenna. Note: I am working on a small inductively coupled loop, not those huge 3 m loops for radio operators and DXing. The book I am using is Antenna Theory: Analysis and Design 3rd Edition by Constantin Balanis, great book. Also Antennas by John D. Krause 1: How do I know it qualifies as a small loop? Balanis gives the stipulation that the radius of the circular loop must be less than lambda/(6*pi) which in my case it is. 2: what is the geometry of my antenna? It consists of a small circular loop on a dielectric board (I think its FR-4) the antenna is not solid wire, it consists of conductive pcb trace, probably etched copper or conductive ink. The circular trace is then connected to two additional traces ending in a female sma connector. There is no ground, the traces connect to the hot wire and negative terminal of the sma to complete the circuit. ______ / \ | | Pathetic, but it will have to do. \ _ _ / | | | | | | OOOO 3. Now to model both designs. I need to compute the external inductance of the loops. I can find these on an impedance analyzer and compute it, which I did for the circular loop. I want to solve for the inductance analytically, and subsequently I can modify my loop geometries/change dimensions for the square. Note: internal inductance is neglected. Balanis gives two equations that approximate the inductance values. La=unot*a *[(ln (8*a/b))-2] eqn 5-37a // circular loop a=radius of loop b=radius of wire, in my case width/2 of trace. I found this circular indutance, equated it to the square loop inductance formula and I extracted the parameters so I can build a square loop of the same inductance. La=2*unot*a/pi *[ln (a/b)-0.774] // square loop 4. Now this handles the values for the antenna. The races that connectto the sma and the loop have their own inductances and contribute to the overall inductance. I need to find that. Originally, I thought I could model it as another circular loop, given the length of the traces. I found the perimeter/circumference and then found the radius. I computed the inductance of the traces as a circular loop. As a first order approximation it wasnt too bad becoz the sum of the circular loop plus the traces =X nH. My exerimental value for the loop was Y nH on the analyzer. A percent error of 10.5% not bad for a rough guess. However, I decided to be more scientific in my approach, so i tried to model the traces as two parallel wires. In Microwave Engineering 3rd edition, Pozar stated: L= mu/pi * cosh^-1 (D/2A) D is the separation distance between the wires center A is the radius of the wire. I have traces so I used the halfwidths as the radii, respectively. However, the results were way too large. So I have to model the traces as something else. I read that some EMC books used flux calculations to derive the inductance values, but that is a bit tedious in computation time. There is also some 3-D model answers, but I just need a fairly accurate approximation. 5. My question is: Has anyone done work similar in this area, and if so could one provide some reference texts or articles or something to assist me? I like my first order guess. I'll go with that just to run a rough em simulation. Am I leaving out some details? Yes. I would not like to divulge them if neecessary. I'd like to just discuss the physics. If anyone can help me, I'd be most apprecitive. Thanks. |
(permalink) | |||||
Experienced Member
Extra note: I start all antenna reviews with "Antenna Engineering Handbook" edited by Richard C. Johnson (older versions edited by Jasik), Mcgraw-Hill. This is a compendium of papers but very well edited to provide a broad coverage of practical antenna forms backed up with basic theory. A decent starting point for many antenna questions.
RadioRon Last edited by RadioRon; 29th December 2007 at 07:24 PM. |
(permalink) | |||||
Experienced Member
2: The sma was already on there. It connects to a 1/4" piece of coaxial cable. I am tempted to model the loop itself, but I am afraid of ignoring the parasitic effects if the two parallel traces. When I determined the inductance of the circular loop antenna, I modeled it as a parallel circuit of a capacitor and a resistor/inductor series part. But now that you mention it, I presume the orginal design of the traces was to mtch the input impedance to the 50 ohm line as well as tweaking the resonant frequency. I have to ask some EMC guys abiut this, problem is they work with suppressing radiation not intentionally to radiate. Quote:
This is why I need to model a square loop. I could do it for Ansoft HFSS, but it costs a lot of money. Quote:
I am a working Rf engineer and a hamster myself. Glad to meet you and thanks. I'll pm in a few. |
| design of a continuity tester | pc88 | Electronic Projects Design/Ideas/Reviews | 2 | 12th June 2007 04:25 PM |
