Old 29th December 2007, 01:46 PM   (permalink)
Unhappy How to isolate and wire?
Hi all,
I am having a knotty problem as to how to wire and isolate pins from pther pins.
Take a look at this pic below, I have drew up.
I have momentary switches S0, S1 ,S2 and S3.
And there are diodes to isolate any switches from other input pins if any one of them is switched on. Only specified switch is tunrned on for its own input pin. The reason why I used this method is to conserve power while lenthening the battery life.
The diagram looks okay except, I cannot think of way to isolate S0 from other SX when shdn is used to shut down power when it is shorted to ground while shdn is switced to 1.2V to wake up. I cannot think of a way to isolate 1.2V from ground. (See the dashed lines)
Your help will be appreciated.
Thanks in advance.
clement
neko_whisker is offline
Old 29th December 2007, 02:28 PM   (permalink)
The diodes all have a loss of at least 0.6V so you won't have much left unless you use germanium or Schottky; what good is 0.6V?
I don't understand your question, build it on a PCB and it should work providing you can actually do something with your pathetic 0.6V
Screen name: Aloone_Jonez
Hero999 is offline
Old 29th December 2007, 02:42 PM   (permalink)
hi Clement,
Can you post the rest of the circuit?, there maybe easier ways to get the result you want..
What are the 4 output pins switching?
Like to help, but cannot see what you are trying to do with the actual circuit.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 30th December 2007, 12:44 AM   (permalink)
Hi Hero999 and ericgibbs,
Here's the pic. I am using it for tranmission project.
I am using RF600E and RTFQ1.
You can see some notes I have written.
Would appreciate your help.
Clement
Old 30th December 2007, 02:13 AM   (permalink)
That doesn't look right to me. For starters, what is LT3525-3.3? I can't find a datasheet for it.
EDIT: I guess you meant LTC3525-3.3.
Ron (aka Rube)
Roff is offline
Old 30th December 2007, 07:03 AM   (permalink)
hi clement,
used your Led indicator(rf600E) to drive the enable (rtfq1) ,but you need to invert led indicator output using transistor(pnp), collector(enable rtfq1), emitter(Vcc 1.2v) ,resistor in between led indicator base .
Publish your web page
jumides is offline
Old 30th December 2007, 10:27 AM   (permalink)
Have a look at this change for the select switches.
Eric
PIC tutorials:
Old 31st December 2007, 12:30 PM   (permalink)
Hi Eric Thank you very much for your help.
What a brillant idea! Wow. I never thought of that!
Now just want to add some wires in order to power up LTC3525-3.3. (Hi, Roff, you are right, My apologies), after shutdown.
Thanks again I will look into jumides' comment even though it has worked before with receiver.
Thanks all.
Old 31st December 2007, 12:37 PM   (permalink)
hi neko,
If your switch contacts are suitable, why dont you use the linking to connect the battery to the LTC..?? no diodes!! and the /shtdwn always enabled??
Eric
PIC tutorials:
Old 31st December 2007, 05:07 PM   (permalink)
1.2V is not a valid logic level for the RF600E. See the table below, which was excerpted from the datasheet. You need to use VCC (+3.3V, in this instance) for your switch levels.
Ron (aka Rube)
Roff is offline
Old 31st December 2007, 08:27 PM   (permalink)
Hi Eric, I have built it before I made changes. The reason? I find that the battery is used up in just 2 or 3 days. That's because if the 1.2V(from battery) is taken away from shdn pin and is left disconnected, it is still active and floating somewhere in the range. So either shdn pin is connected to above 1v or 0V, it will be in active or shutdown mode respecively. That is, I want to enable or disenable LTC3525-3.3 by any switches, to conserve battery's power. You may refer to datasheet. And I am surprised that 10uH inductor is connected to shdn pin in your drawing. How is it possible? see page 7 of this datasheet.
Roff, I am aware. But I connected 1.2V to SO via diode and it still works. If not, how do we isolate S0 from other switches, if we want to enable and disenable LTC3525-3.3?
Please advise. Thanks in advance
Old 1st January 2008, 09:44 AM   (permalink)
hi neko,
The idea in the last drawing, is that the push buttons that are wired in series, have one end connected to the 1.2Vbty and the other end connected to the LTC.
So without a PB pressed the LTC is not powered up, pressing any PB puts power on the LTC and of course you want the /shtdwn to be disabled[high].
Also note what Roff is saying about the RF600 logic levels, you could rewire so that these are connected to the LTC Vout.
Do you follow this OK?
EDITED: the /shtdwn is connected to Vin of the LTC and the 10uH, which connected to the 1Vbty when a PB is pressed
Eric
PIC tutorials:
How to wire an Opto 6N136 CNCwt General Electronics Chat 14 2nd December 2007 07:01 AM
Introduction to High Brightness LEDs and Thermal Management Ocelaris Electronic Projects Design/Ideas/Reviews 3 17th March 2007 06:35 AM
Problems with Dual Brightness (Current) LED Tail Lights? Eagle Schematics! Ocelaris Electronic Projects Design/Ideas/Reviews 12 31st December 2006 07:18 PM
