| Hi I have to build a traffic light(red-50s & green-30s) with 74ls192(3 IC),Lm555,relays,logic gates(AND,NAND,OR,NOT),7-segments and 74ls47.could someone help me with this circuit? I dunno where to use relays and logic gates,also I wanna know how three 74ls192 connect to each other? | |
| I've made a similar circuit with a CMOS 4017. I haven't looked at the datasheet, but there should be a "carry" pin so you can link the final output to the input on the next IC for it to keep counting along. Use the diodes to link your outputs together, eg. when you want a red lights on at different times, do not connect IC outputs together directly, instead use two (or more) signal diodes (this is effectively your OR gate) to the outputs and LED/relay respectively. Depending on the wattage the IC(s) can handle, you may need to use your relays to trigger the LEDs. You say you "have" to build this? Is it a uni project or something that has to meet criteria? I'm sure some more experienced enthusiasts can help you out with the 74LS192. Good luck. | |
| Hi swallowbird, is the traffic light used for pedestrian's crossing? I'm missing the yellow light in the threat. Secondly: Should the design be for a four-way-intersection? Boncuk | |
| This is a frequent topic. Search for traffic signal homework. | |
Hi Duno if it helps but here is a schematic. Mark | ||
connect lm555 output to 74192(1)count up clock, 74192(1)carry up to 74192(2)count up clock , 74192(2)carry up to 74192(3) count up clock
__________________ Publish your web page | ||
| Traffic light circuit question | moody07747 | General Electronics Chat | 5 | 5th June 2005 03:22 AM |
| Led cyclic dimmer/controller circuit? | yel-low | Electronic Projects Design/Ideas/Reviews | 13 | 9th August 2004 05:00 PM |
| Light to voltage circuit wanted | Jules | Electronic Projects Design/Ideas/Reviews | 10 | 8th July 2004 09:54 AM |
| Lighthouse flashing light circuit | zman | Electronic Projects Design/Ideas/Reviews | 8 | 8th August 2003 10:05 AM |
| Actual Size Traffic Light Controller WITH SWITCHPACK | mrdexterous | Electronic Projects Design/Ideas/Reviews | 2 | 10th June 2003 06:29 AM |
