| Doubt it, I have not had one of those 1N914 diodes fail in nearly 17 years on metering led potential circuits. The resistors take care of the voltage drop.
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. | |
| fever Basically put 2 strings of 10 LED's in anti parrallel. for a 20 LED lamp. For white LED's that is about 30 Volts drop, You need to get rid of ( 220-30 ) = 190 Volts in the series resistors. Run these at 5.75 mA than a 33 k ohm resistor would suffice. From U=I*R 190 / 33000 = 5.75 mA. Power rating P=I²R then 0.00575² * 33000 = 1.1 Watts dissipated in the series R's. I would go for 2 * 15 or 18 k. ohm 1 or 2 Watt series resistors to spread the heat a little. For your 5 Led lamp I would put 2 Led's in forward mode and 3 Leds in reverse. Then use a 39 k ohm series resistor. or make it up from 2 * 22 k Ohms. It is good practise to check the actual LED current in your circuit with your multi meter. I find that most high efficiency LED's give excellent brightness at 5 to 8 mA's. and i only have used 3000 to 5000 MCAD Led's.
No problem using those diodes!. | ||
A by-passing diode, which is connected in anti-parallel with the LED, would reduce the reversed voltage across the LED because of its forward voltage drop of 0.6V. I was referring to the first case.
__________________ L.Chung | ||
| @RODALCO i made a simple circuit diagram.pls have a look and let me know abt the mistakes. http://img20.imageshack.us/img20/7014/wena9.jpg and for application i will run this setup for 12 to 15 Hrs.so is it safe. | |
| Thanks Audioguru for your quick reply to fevers question. Correct! it won't work. Just in words now. [Phase] - [18 kOhm 1 Watt R] - [LED LED LED LED LED ....... LED biassed one way in parrallel with LED LED LED ....LED reversed way] - [18 kOhm 1 Watt] - [Neutral]. I haven't got a drawing programme so i will take a photo and add it later.
| thanks.even a rough paintbrush image is sufficient for me.i'll make good one with eagle. (make a rough sketch for both 20,5 led application) | |
| See if these GIF images come out. Downloaded some drawing programme Regards, Raymond
| thanks for the circuit diagram. but the 4148 and 4007 diodes are missing.4007 is in series with the phase side resistor but what abt the 4148.how shld i connect it. and is the resistor the only thing which decides the life of the whole circuit? bcz till now i used ur circuit for only 1 LED(since 1year with continuous usage of at least 10Hrs) 20 LED circuit will draw pretty amount of current.so is this circuit suitable for 10-12Hrs operation? | |
| | (permalink) | ||
__________________ Uncle $crooge Last edited by audioguru; 2nd January 2008 at 08:02 PM. | |||
| Hi Rodalco, I would feel a lot more confortable if the leds were connected antiparallel, it's the only way to be make sure that the reverse voltage is evenly divided amongst all leds. Or is it just me being paranoid ? on1aag. | |
| Thanks audioguru for your quick reply, In between posts here on this forum we had a 10 MVA, 33 kV / 11 kV substation blow up in my area and lost power for 3 hours. I was called out to do power restoration HV switching and fault assesment of the transformer. cause, overload and old cable on1aag You can do it the way you suggested as well, each pair of LED's in antiparrallel and make up a series string with 10 of those LED pairs. It is interesting how a DC LED lamp topic turns out into an AC LED lamp topic. Still good to keep all bits together. Regards, Ray
| 120 VAC to LEDs Look up On Semiconductor NUD4011. Figure 8 of the data sheet shows: Full wave bridge IC Resistor ¼ watt LEDs | |
| Junebug Assembly Tips | Krumlink | Micro Controllers | 187 | 18th May 2008 04:20 AM |
| LED Matrix Project Debug, Please Help :[ | mekohler | Micro Controllers | 2 | 7th December 2007 07:57 AM |
| 24 volt output, 12 volt charger | bigpaddy_irl | General Electronics Chat | 7 | 14th November 2007 05:48 PM |
| P channel FETs vs N channel FETs for LED Matrix applications ?? | tdg8934 | General Electronics Chat | 3 | 9th September 2007 06:17 PM |
| 6 volt dc circuit to 12 volt lights | jace33 | Electronic Projects Design/Ideas/Reviews | 5 | 20th October 2006 11:39 PM |
