Old 25th December 2007, 03:15 AM   #1
Default Neeed help ``part1
From this page http://www.uoguelph.ca/~antoon/circ/tx15trak.htm
I wanted to know when i will build 1 .Can i use for C1 a a 6.6volt capacitor or a 16v capacitor.
For C2which disk capacitor do i hav to use`????
disk capacitor 2kv 470pf
disk capaci. 2kv 330pf
disk capacitor 2kv 560pf
disk capacitor 2kv 270pf
cond. 680pf 10% 2kv
disk capacitor 3kv 820pf
also: c3000 1k also: c
capacitor also: c30
disk condensator
disc cap. 3kv 2.2n
disk capacitor 2kv 1200pf
disk capacitor 2kv 2200pf
disc capac.3kv 1.2n
disc capacitor 3kv 1.5n
disc capac. 3kv 1nf
disc capac. 3kv 2.2n
And from C3 which trimmer capacitor?????
2320-2
trimmer/variable capacitor (johanson manufacturing)
2320-3
2322-0g
2322-1g
2322-2g
2322-3g
27263
27271
27271sl
27283
27291sl
47273
5201
5401
5402
5501
5601
5641
8052
9301
9302
9304
9305
9315
9328
9341-2sl
9341-3sl
9341-5sl
9341-6sl
9341-8sl
9341-9sl
9342-14r1
9342-16r1
9343-17r1
9343-18r1
9343-19r1
9372
9374
9376
9385-1sl
9385-2sl
9385-3sl
9385-4sl
9401-0
9401-1
9402-0
9402-1
9402-2
9402-6
9410-5
9701-0
9701-1
9702-0
9702-1
9702-2
9702-6
9710-1
9710-5
ctz3e-10a-w1-pf
trimmer/variable capacitor (avx)
ctz3e-30c-w1-pf
variable capacitor trimmer capacitance m (avx)
ctz3e-40c-w1-pf
tzw4z1r5a001r00
trimmer cap, high power (murata)
TRIM10/5
trim capacitor 2-10pf
TRIM10P
TRIM22P
trim capacitor 4-20pf
TRIM30P
trim capacitor 3.3-33pf
TRIM100P
trim capacitor 7-100pf
TRIM39P
trim capacitor 5.5-40pf
TRIM65P
trim capacitor 5.5-65pf
TRIM80P
trim capacitor 5.5-80pf
and for C4 which disk capacitor????`
cond. 680pf 10% 2kv
capacitor also: c30
disk condensator
disc cap. 3kv 2.2n
disc capac.3kv 1.2n
disc capac. 3kv 1nf
kartulisupp is offline
Old 25th December 2007, 06:05 PM   #2
C1 can be 6.6v or 16v.
C2 has to be 10nF or 0.01uF. As long as it's over around 3v it should be fine.
C4 is 4.7 pF As long as it's over around 3v it should be fine.
If you aren't afraid of life then you aren't paying close enough attention.
CynicalMan is offline
Old 25th December 2007, 06:44 PM   #3
Default help ??????
R1-10K.
is it like a switch or a piece if it is just a piece how many W does it have to have?????????????????????????????????????????????? ??
Old 25th December 2007, 09:17 PM   #4
It's a resistor, and it only needs to be small - 1/4W is fine.
Old 26th December 2007, 01:14 AM   #5
th2nk u soooooooo much.
Old 26th December 2007, 01:26 AM   #6
Default help ?????
For this construction!
For C1 the electric capacitor how many volts can it be?+
Can I use a 6.3 V or 16 V one?
Old 26th December 2007, 01:30 AM   #7
really i soo appreciate it
first electronic thing that ill be doing
so thats why i dunt know anything
Old 26th December 2007, 01:33 AM   #8
The voltagew across C1 in the circuit is very low so either capacitor's voltage rating is fine.
audioguru is offline
Old 26th December 2007, 01:34 AM   #9
thnx i appreciate it
Old 26th December 2007, 01:41 AM   #10
Default help ????
for this construction!
For C2 can I use this part ?
http://www.oomipood.ee/index.php?t=k...ARNELL_1009893
Old 26th December 2007, 01:51 AM   #11
The part you provided a link for is rated at 600V. a 100V capacitor will work the same, it will be smaller and it will probablybe less expensive.
Old 26th December 2007, 02:23 AM   #12
Its Cheap enough for me !!!
In American dollars its under 50cents 1
Old 26th December 2007, 02:35 AM   #13
Default last help??for now
from that page C3-is from this page
http://www.oomipood.ee/index.php?t=k...ARNELL_1215715
the part the right one
For Q1- Is this the right part for it
2n3904: si transistor npn 40v-0.2a-300mhz
Specifications
type number: 2N3904
description: si-npn lp
ratings: 40V-0.2A
remarks: 300MHz
Old 26th December 2007, 03:29 AM   #14
Good luck trying to find a LM3909, been obsolete for years.
Super_voip is offline
Old 26th December 2007, 03:53 AM   #15
can i put a different one that would hav the same effect
neeed, ``part1
neeed help salman007 Datasheet/Parts Requests 9 4th April 2007 10:17 PM
