Old 3rd January 2008, 04:20 AM   (permalink)
Originally Posted by audioguru
The type of FET you use and how it connects depends on the polarity of the POP.
POP ?! the one i heared, how i know its polarity?
Its what your friend in Your mind, what you in your friends mind
aljamri is offline
Old 3rd January 2008, 04:39 AM   (permalink)
Look at it on an oscilloscope.
audioguru is offline
Old 4th January 2008, 03:53 PM   (permalink)
If you don't have a scope you could connect a pair of LEDs wired in reverse parallel to the output.
Screen name: Aloone_Jonez
Hero999 is offline
Old 6th January 2008, 01:39 PM   (permalink)
Like the attached connection ?
aljamri is offline
Old 6th January 2008, 03:05 PM   (permalink)
Yes.
Hero999 is offline
Old 11th January 2008, 03:48 PM   (permalink)
I've connected the attached circuit between the output and the Ground and used a 2khm: variable resistor set at 50% at the begining and switch on the reverb supply. i've got no indication, gradually i reduce the resistance and try again until reach around 500hm: where i got the forward bias LED on when i switch the reverb on.
is that enough to know which JFET to be used to stop the pop sound ?
aljamri is offline
Old 12th January 2008, 07:17 PM   (permalink)
Sorry This is the circuit i used for the test.
aljamri is offline
Old 12th January 2008, 08:41 PM   (permalink)
You have a positive-going POP when the power supply is turned on. Then you could add a resistor in series with the output and a P-channel Jfet with its drain at the resistor and its source connected to ground. Its gate voltage is 0V when the power supply is turned on so its channel is a low resistance which will attenuate the POP. Then use a resistor from the positive supply to its gate and a capacitor to ground to slowly charge and allow the sound to pass through.
But the jfet might still conduct a little during sounds which will cause distortion. And the series resistor increases the output impedance of the circuit.
"Miracle Tube" produces more Energy than put in (Yes, another one...) Analog Chit-Chat 7 21st September 2007 01:58 AM
