| connect .001/50v or other value, mylar capacitor across ground, ic pin no.6 ic2b.
__________________ Publish your web page | |
| The microphone needs to feed a preamp that is designed for a dynamic mic then its output level is well above the level of the hiss. Then your reverb circuit can feed a line input on the power amplifier so the hiss is not amplified. If your mic cable doesn't pickup mains hum then its length is fine. When you remove the battery from your reverb circuit then it should not produce sound, not even hiss. If you unplug the output of the reverb circuit from the input (which input?) of the power amplifier then is there still hiss?
| http://www.securitywarehouse.co.uk/c...roducts_id=880 where did you connect your preamp output ( aux or mic input )?
| | (permalink) | ||
Thanks for your replyssssssssssssssss.
__________________ Its what your friend in Your mind, what you in your friends mind | |||
If its input is non-inverting then I would increase the gain of the first opamp so it is a preamp.
| look at your circuit there's no gain control, audio coming from (input) ic2b then out to ic2b going to resistor 24k then going to input(ic2a) then out ic2a output directly connected to you mic input . which means that signal are to high for mic input, all noise will be amplified generated by opamp. level (100k) controls a reverb section. like nigel said, you need a preamp, if your going to connect your reverb to aux . Quote:
I made my mistake, I'm pointing to his reverb. hi audioguru,nigel correct me, if I'm wrong. with my analysis
__________________ Publish your web page | ||
The signal from the mic is too low for this reverb circuit which normally has line level signals at least 60 times higher. So the noise from this circuit is amplified at least 60 times by the mic preamp that it feeds.
| hi audioguru, Quote:
forgive me, some mistake again!!, I just want to help mr aljamri. it should be like this, " look at your circuit there's no gain control, audio coming from (input) ic2b (tl072)then out to ic2b(tl072) going to resistor 24k then going to input(ic2a) then out ic2a output directly connected to your mic input(pa amplifier) . which means that signal from the reverb(opamp) are to high for mic input(PA amplifier) , all noise generated by opamp(TL072) will be amplified by mic input(pa amp). level (100k) controls a reverb section. " thanks for reply.
__________________ Publish your web page Last edited by jumides; 28th December 2007 at 10:21 AM. | ||
| Happy New Year for everybody, It is me again but with good news this. I've added a pre-amp as Nigel suggested using TL071 as audioguru suggested and the voice became quite good that made me to reduce the PA volume which resulted in low noise at output ( but not zero ). so I told myself why not to check jumids suggestion and put a piece of aluminum underneath the circuit, isolate it and connect it to ground. This made noise to ZERO. So my circuit has no hiss and no need to put your mouth on the Mic. Thanks all of you again (Radio Ron, jumides, Nigel Goodwin, audioguru and Hero999 for you valuable participation to my circuit.
| Hi everybody and happy new year, I don't know if it is OK to continue on another issue for the same circuit here in the same page or i should start a fresh one ? for now i'll ask here in the same page and If i'm wrong please anybody tell me to immegrate to a new one. I added a switch to my reverb circuit to switch it off when not in use ( Thumbnail01). The problem is that when i switched it ON/OFF while the PA is ON, a bang nose is heard out of the speaker. Similar devices uses JFET switch instead. Is it possible for me to connect one here? In my hand a 2N5457 is O.K. for this purpose ( Proposed Circuit Thumnail 02, Datasheet Att.03 ). Thanks
__________________ Its what your friend in Your mind, what you in your friends mind Last edited by aljamri; 1st January 2008 at 06:21 PM. | |
| I am amazed that you used a lousy, noisy old 741 opamp and it doesn't cause hiss. I would use a low noise TL071 opamp for a mic preamp. I don't think the POP comes from the opamps because their Vb slowly drops when the power is turned off. I think the POP comes from the echo IC. The circuit must be observed on a 'scope to see if it abruptly goes high or goes low. Then a FET can be added to disconnect it when the power is removed.
| | (permalink) | ||
http://www.electro-tech-online.com/e...processor.html In my last working fine circuit, I used TL071 as per your recommendations. Quote:
Thanks for all
| The type of FET you use and how it connects depends on the polarity of the POP.
| "Miracle Tube" produces more Energy than put in (Yes, another one...) | Analog | Chit-Chat | 7 | 21st September 2007 01:58 AM |
