Old 24th December 2007, 04:34 AM   (permalink)
Default novice help 555 timer
i was trying to build a timer with a 30 second on and a 3 minute off, i tried using the circuit below on kpsec.com, the one using a diode to get less than a 50% duty, i used r2=1.2M, r1=0.2M and c1=220uF according to the calcs on that page. The output stays on, does not cycle, whats wrong? i also tried it with c1=47uF, same result
if i change out c1 to 10uf the timer will cycle about 1 sec on and 8 secs off
http://www.kpsec.freeuk.com/555timer.htm
wfontjr is offline
Old 24th December 2007, 07:43 AM   (permalink)
555 timers are very limited as to maximum times, in this case the leakage in the 220uF is probably more than the current available through the 1.2Mohm - you could try using a tantalum capacitor?, this is an application where they really are better.
Old 24th December 2007, 01:25 PM   (permalink)
thanks for the help
wfontjr is offline
Old 24th December 2007, 02:12 PM   (permalink)
What are you using it to control?
A relay, LED, piezo buzzer etc.?
Just omit the diode and wire the load from pin 3 to +V instead of 0V.
Screen name: Aloone_Jonez
Hero999 is offline
Old 24th December 2007, 06:17 PM   (permalink)
i have it on an led for testing, i planned on using in on a relay to start/stop a livewell pump
wfontjr is offline
Good 555 timer tutorial. Hero999 Electronic Theory 24 2nd October 2008 12:15 PM
555 timer traffic light cb4 Electronic Projects Design/Ideas/Reviews 9 12th December 2007 07:53 AM
555 Timer AND NOT Sumo Bot? Krumlink Robotics Chat 2 29th November 2007 03:42 AM
Help with timer and interrupt please.. AntRoFiZ Micro Controllers 2 29th May 2007 11:48 AM
:: Timer 2 Woes :: suby786 Micro Controllers 2 5th May 2007 11:13 AM
