Old 23rd December 2007, 06:04 PM   (permalink)
Default test tube liquid level calculator
Hello people , I’m new here and a friend told me that maybe I was able to get help here.
I’m running a test on fuel delivery on a series of diesel fuel pumps, using a calibration test bench with, the problem is , that the way the volume is recorded is via a calibrated test tube , and you are to obtain the result of each injector visually , for the purpose of my project visual readings are not that accurate (varies depending on visual angle ) and takes lots of time . I also need to keep records of all testing results and conditions.
I was thinking of a flow sensor , but they are to expensive and the biggest total flow is 50 cc , a friend subjected a rage finder but the tube is inch 12 inches long and there are 18 of them.
if it s at all posible i will like it to be displyed and recorded on a pc
Any ideas?
Estroncium is offline
Old 23rd December 2007, 06:28 PM   (permalink)
Any ideas?
Well with 18 test tubes to measure (all at one time?) there will be costs. I like the concept of using strain gauges to measure the weight of the total tube. Software can subtract the tear weight of an empty tube giving the resulting weight of the contents. Straing gauges can be quite accurate and repeatable. Check out Omega.com for information on strain gauges.
Lefty
Measurement changes behavior
Leftyretro is offline
Old 24th December 2007, 12:02 AM   (permalink)
As lefty said: "there will be costs", either in time or money.
You might want to take a look at a design for a "capacitive fuel level" circuit. Two insulated rods in each of your sample tubes. Output is a frequency that varies with depth. This should be cheap enough to make 18 parallel versions, fed to a PC interface that can read the frequency/period of the outputs and log it against calibration tables (if you need high accuracy) for each probe.
http://www.rst-engr.com/kitplanes/index.htm
Go down to June/July/August 2000
Ken
KMoffett is online now
Old 24th December 2007, 02:29 PM   (permalink)
yes all at the same time...thanks for the starting point.. now .. i need to start reading... and working on my other esperiment ..."how fast can one make a disatarter during turkey preparation",,,,
Merry Xmas......HO,,HO ,,HO
Old 24th December 2007, 06:36 PM   (permalink)
Arrow
ok here we go ,,, I think i need one of this http://www.omega.com/ppt/pptsc.asp?r...-XL&Nav=dasb01
using somthing like this
http://www.iotech.com/catalog/daq/persdaq3000.html
to reed the data coming out of this....
http://www.omega.com/ppt/pptsc.asp?r...KFG&Nav=pree02
now i have the pices ,,,how do i get the to work together,,how do i plug a Strain gage to the loger? ....
bdw the tukey esperiments results (22.5 minuts)
Liquid Level Measurement/2 Joe McGivern General Electronics Chat 17 15th May 2007 09:12 AM
connecting an optical liquid level sensor davidnprop General Electronics Chat 3 6th May 2007 08:51 PM
Liquid Level detector and indicator Langat Electronic Projects Design/Ideas/Reviews 4 27th September 2006 03:13 PM
liquid level circuit?? jerfude General Electronics Chat 1 13th January 2004 06:06 AM
About and Liquid level display mishranirmal Electronic Projects Design/Ideas/Reviews 1 13th September 2003 03:48 AM
