Hey everyone, I recently built an H-bridge with four darlington pairs being fed by PWM from a pic. I have two questions/concerns: 1.) Is it possible to run both an H-bridge and a motor from the same power source without significant interference on the logic side? I'd like to run the h-bridge at 12v, then use a voltage regulator to supply 5v to the PIC. Can a regulator provide clean and stable enough power from the noisy h-bridge circuit? 2.) I built an LM317 based bench power supply to use for projects like this. However, when I use it to supply motors the performance of the motor degrades over the first minute or so and often stops. Can LM317 based power supplies be used for small motors? I also notice it sometimes acts funny when supply circuits with large capacitors. The LM317 is kept very cool (large heatsink with fan) and the motor doesn't draw more than 1 amp. Right now I am running my motor with a 9v battery and it works better than the PSU. | |
If you post the circuits that you are using perhaps we can help you. Even with a power supply extra filtering is sometimes required for loads on the power supply, such as a motor. If the motor has brushes the noise generated by the brushes can cause the 317 to malfunction. A electrolytic capacitor near the motor terminals may help but it can cause surge current problems with the 317 if a protection diode is not used.
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | |
Hi, I dont understand why u need regulated supply when u have a PWM controlled H bridge | |
The power supply powered the entire circuit, working with a transformer and rectifier to bring the mains voltage down to a more reasonable 12v DC. Since someone brought this topic back, I might as well let everyone know what I discovered. The motor was drawing WAY more current than I thought. I used to think that the lm317 would just turn off if I tried to draw too much current, when in reality it just limits the voltage at the output. So when I hookup up the motor it worked fine for the first few seconds but slowly degraded in performance as the 317 lowered the output voltage to protect itself. | |
Whay not just use the non regulated output directly from the filter capacitor to power the h-bridge? Motors aren't bothered about voltage regulation, in fact it's probably better to use the non-regulated supply because the regulator will stop some of the noise generated by the motor from affecting the rest of the circuit.
| | #6 |
The transformer I have brings the mains voltage down to ~25v, I was using the regulator to bring it from there down to 12v. Anyway, I got the circuit working, I just had to use a different power supply that could provide more current. | |
| | #7 |
You could easilly run it at 25V, if you're worried about overloading it, then never run the PWM at more than 50% duty cycle.
| motor, power, questions, supply |
| Questions leading to small project (Laser Vortex) | Norritt | Electronic Projects Design/Ideas/Reviews | 0 | 17th October 2007 06:48 PM |
| opamp audio mixer - single supply | fvnktion | General Electronics Chat | 7 | 11th July 2007 08:16 PM |
| Halogen Lamp as Power Supply? | grrr_arrghh | General Electronics Chat | 4 | 14th May 2004 11:42 PM |
| 24v 2.5 amp power supply......some questions | JGS93GT | Electronic Projects Design/Ideas/Reviews | 10 | 14th February 2003 11:27 PM |
| Power supply/ current supply design | inkedallusion | Electronic Projects Design/Ideas/Reviews | 1 | 17th December 2002 02:10 AM |
