Old 21st December 2007, 11:41 AM   (permalink)
Default stepper motor control project
Hi friends,
I work on project.I control two stepper motor using PC parallel port.I done programming in turbo C.I enter stepper motor speed,keyboard keyevent to rotate motor in perticular direction & also enter angle to rotate stepper motor.
Now i want to change in my project. I want to use USB port instead of parallel port.
Is it possible?
yes then How ??.. For that my application remain same.Only change use USB port instead of parallel port.
Thank you..
diyora is offline
Old 21st December 2007, 12:04 PM   (permalink)
Your project would change MASSIVELY - both hardware and software would be completely different, you would need a processor to feed the stepper motor drivers - and you of course be using Windows and not DOS.
Old 21st December 2007, 01:20 PM   (permalink)
Hi Nigel,
Thanks for reply & suggestion.Above project i done in windows only.
Can you please give me the idea about which processor required?.How?.
As i think ,it would be only requiredment of microcontroller.I required data trasfer speed is 3.5 Mbps to 4 Mbps.
Thank you..
diyora is offline
Old 21st December 2007, 01:43 PM   (permalink)
I don't see as there's any need for any great speed?, you're sending data to a stepper motor, which is an exceptionally slow device.
The easiest way do USB is to use a USB/Serial converter, so your PC program accesses the interface as a simple serial port, and your processor connects via a serial link to the converter.
Alternatively you could use a processor that has it's own USB interface, but this is much more complicated.
Any PIC (or other micro-controller) would be able to easily handle such a simple task. Where before your PC program actually controlled the stepper, now the PIC controls the stepper - you simply send it instructions, and it carries them out (something like L45 - for 45 steps left?).
Old 21st December 2007, 02:22 PM   (permalink)
Hi Nigel,
Thank for reply.This project like security camera control.In future suppose i want to control also video signal so i required 4 Mbps data trasfer speed.
As you suggest USB to serial cable(dongle).I find out but it data trasfer speed is between 500 Kbps to 1 Mbps.So,it is not useful to me.
I think about high speed microcontroller but iit also fullfil my requiredment as i mention in my first thread.
Can you give me any useful suggestion?
Thank you..
diyora is offline
Old 21st December 2007, 02:36 PM   (permalink)
You might check the PIC 18F series at MicroChip, many of those have USB interfaces, or perhaps the dsPIC's as well?.
But USB is very complicated!.
A good place to satrt might be the USB Bit Whacker project?
http://greta.dhs.org/UBW/
Old 21st December 2007, 03:26 PM   (permalink)
You might want to explore the FT245R IC (USB to parallel)
http://www.ftdichip.com/Products/FT245R.htm
Bill
Smart Kits build Smart People
Old 22nd December 2007, 06:10 AM   (permalink)
Thaks for reply.I see both ic FT245 & PIC 18Fxx.In both ic there is no mention the data transfer in communication(Run time)mode.There is only giving write & read speed.
Now about FT245 is USB to parallel converter so as i think this will reduced the data speed.
PIC 18Fxx which not clear for me.
Can yyou give me proper idea about this ??..
It also support the video signal.
Thank you..
diyora is offline
Old 22nd December 2007, 07:43 AM   (permalink)
USB is quicker if you transfer larger blocks of data at a time. Transferring one byte at a time is slower and eats up CPU cycles on the host PC. It would be better to use a PIC and then write a program to buffer stepper commands from the PC so that you are writing high speed bursts of data over USB while the stepper turns relatively slowly.
kchriste is offline
Old 24th December 2007, 05:51 AM   (permalink)
Thank you..
The FT245 can take data far faster than a stepper could use it.
What do you mean by video signal?
Are you trying to build a pan and tilt video camera?
Bill
Old 25th December 2007, 04:17 AM   (permalink)
Hi blueroomelectronics,
Thanks for reply.You are thinking correct.I want to build pan & tilt video camera.So in future video signal there.
Is this ic(FT 245) support high data transfer speed with video signal ??..
Thank you..
diyora is offline
Old 25th December 2007, 01:10 PM   (permalink)
I would suggest your first problem is converting the video signal to a USB data stream, and presumably using MPEG2 compression to make it a reasonable size?.
Old 25th December 2007, 08:35 PM   (permalink)
You might check this thread for the video input: http://www.electro-tech-online.com/e...rocessing.html
Microsoft DirectX 8 and later SDKs have a sample USB camera input program that you can work with. They give you a pointer to live video bitmap pictures in memory that you can intercept for comparisons etc.
DirectX is for Microsoft C and C++ or visual Basic. Unless you have been there before, it will take lots of reading.
C:\WHUT ?
Beware the asterisk *
ClydeCrashKop is offline
Old 26th December 2007, 09:29 AM   (permalink)
Hi all,
Thanks for reply. Can you first clear my doubt...?
Is it possible in high data transfer microcontroller to pass the video signal ?.
Because in future I have 4 video signal which is only pass through it.
Thank you...
diyora is offline
Old 26th December 2007, 01:08 PM   (permalink)
No, you can't just 'pass a video signal through' a micro-controller, it's a high bandwidth analogue signal.
Uni Project Advice 2-tone Electronic Projects Design/Ideas/Reviews 7 18th October 2007 01:11 AM
stepper motor project help required armess Electronic Projects Design/Ideas/Reviews 6 25th July 2007 06:28 AM
Stepper code for PIC raitl Micro Controllers 6 15th February 2005 02:45 PM
Project needed, Stepper motor controller PIC based lompa Electronic Projects Design/Ideas/Reviews 1 11th October 2004 07:57 PM
project using stepper motor belstud Electronic Projects Design/Ideas/Reviews 1 9th March 2004 07:42 PM
