| I am doing some research on building a charger for my 12v sla (sealed lead-acid) battery. The requirement is simply bing able to start and stop charging automatically. I realize there is good information on the web (for example, http://electronicdesign.com/Articles...ArticleID=1823) Ok, the regulated power supply I need should be rated at about 15 volts. However, I am thinking if there is some circuit failure (for instance, diode failure) on the power supply and it is not giving out 12-15 volts dc, am I so-called "back-charging"? So in the case my power source becomes 7 volts and not 15volts, I am further draining the SLA battery that sits at 11 volts!! In that case I know my charger is not doing its job. But will it cost my battery or blow up my other parts of the circuitry, I am wondering? (please give a refresh to my rusty brain.) Thank you so much. | |
| Here is a circuit for a PowerSonic SLA battery charger. I drew it up while repairing one. The diode D6 prevents the battery from draining back into the charger. The circuit has an LED (D4) to indicate when it is on high charge and a section to automatically fold back to a trickle charge. ![]()
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |
| Thank you for your circuitry. The one I got from the web requires a relay but yours does not, which is good. I am not too sure how this circuitry works without testing it. A normal Lead-Acid battery should be "heavy" if it is beween 12.8 and 13.1 volts. According to your setup, you make the un-loaded output voltage to sit between 13.98 v and 14.98 v (which will be 13.28 and 14.28 v under normal load). Will your setup be ok? Another question is, how would you suggest me to revise the given circuit, given that I want to add some Auto turn-on and turn-off circuitry to my existing regulated 16 V dc supply. (I think I can remove the diodes and the LM1728 regulator totally) Thanks. | |
| First, the LM7812 (is LM1728 a typo?) is there to be a switchable regulator. It's output is set by R8 to provide a high charging current. As the battery's terminal voltage approaches this voltage, the charging current drops. This is sensed at R5, and the LM7812 is switched to a lower voltage output, set by R7, that is used to maintain a trickle charge to the battery. The voltages at the output terminals were selected from data sheets for SLA batteries and adjusted to maintain a charging currents required by this circuit. You could replace T1, D1, and C1 with a regulated supply, but it would need to be 18vDC or greater, to overcome the U1's minimum I/O differential and the Vf drop of D6. Removing the LM7812 would defeat the whole point of this circuit. The circuit switches from high charge current to trickle charge. If you want to do something with your existing regulated 16V power supply you will need to find a different approach. Adding a diode to your original circuit's output (as in my D6), and having the relay cut the power to your regulated supply would probably do what you envision. This was just an offering of the design of a commercial charger I'm currently using. Ken
Question: I can't figure out how D3 and R5 in the diagram function, and Q1 gets no biasing voltage. Is this a slight drawing mistake? Thank you again. | ||
| It took a while for me to figure out how it worked too. Ken
| Using mini-solar panel to charge batteries | sir Ene | Electronic Projects Design/Ideas/Reviews | 15 | 26th August 2006 10:10 PM |
| Battry charge cut & on | Rakesh Sharma | General Electronics Chat | 4 | 2nd January 2005 04:07 AM |
| Charge Capacitor Bank | bd13 | Electronic Projects Design/Ideas/Reviews | 6 | 28th November 2004 11:47 PM |
| Charge Amplifiers | newb | Electronic Projects Design/Ideas/Reviews | 1 | 7th May 2004 01:42 PM |
| charge amplifier wat and how? | newb | General Electronics Chat | 0 | 5th May 2004 05:48 PM |
