There should be a second breakdown spot on the SOA curve in that daatsheet then as well. | ||
| You can connect Mosfets in parallel because their on-resistance increases when they get hot. The opposite of junction transistors.
I've only seen power mosfets with a positive TCR. | ||
| The power dissipation in the Mosfet is maximum when its resistance equals the load resistance. When its resistance increases above the load's resistance then its power dissipation becomes less.
| Optikon you are right if the MOSFET is in an amplifier and biased for class A operation. AudioGuru is right when the MOSFET is used as a switch in say a class D amplifier. Two different applications and two different effects as the junction temperature increases. As you can see from the diagram, at high drain currents the SOA is limited by the RDSon value which increases with temperature. (IRLZ44)
__________________ --- The days of the digital watch are numbered. --- Last edited by kchriste; 22nd December 2007 at 05:26 AM. | |
