+ Reply to Thread
Results 1 to 12 of 12
Thread: how to solve this problem ?
  1. #1
    ☼☺☼coool☼☺☼ Bad ☼☺☼coool☼☺☼ Bad
    Join Date
    Dec 2007
    Posts
    29
    Default how to solve this problem ?
    hey,this is my first post so Iam new at this site so could you help me please to solve my problem ?
    my problem is that I build a RF transmitter at frequency of 96MHz and I got a ready made receiver which has a band from 88 - 108 MHz but when I transmit a square signal I dont receive it propeply...I get a distorted signal...what should I do ?
    ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,793
    It's an audio transmission system, you can't send plain data via it - you need a modem either end.
  3. #3
    jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent jpanhalt Excellent
    Join Date
    Jun 2006
    Location
    Cleveland, OH, USA
    Posts
    1,589
    Where did you find a ready made receiver for square waves? What did you expect to hear without modulation?You probably have an FM receiver and are detecting the harmonics from the square wave you say you are transmitting.
  4. #4
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,871
    A good FM radio can receive a square-wave that is from about 200Hz to about 2000Hz from a good FM transmitter.
    Square-wave frequencies below 200hz will have tilt and curvature because the response drops below 50Hz. Frequencies above 2000hz will not have steep sides on the square-wave because the response drops above 15kHz.
  5. #5
    Join Date
    Jun 2006
    Location
    Cleveland, OH, USA
    Posts
    1,589
    I guess originally I read the OP differently than you did . To quote, "my problem is that I build a RF transmitter at frequency of 96MHz ... but when I transmit a square signal I dont receive it propeply...I get a distorted signal..."
    I read that to mean the OP was transmitting a square wave at 96 MHz and was getting only noise. That didn't make sense to be doing, so I asked what he expected without modulation. Obviously, you read the post to mean that the modulation was a square wave, but the carrier at 96 MHz was a typical carrier.
    In retrospect, I agree that your interpretation makes more sense than mine did. Still, it would help if the OP would clarify what he was sending as a signal. John
  6. #6
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,871
    A "ready-made" receiver for 88Mhz to 108MHz has an audio output, not a square-waves RF output.
    It would help if the OP said what is the frequency and attached a 'scope picture of the distortion. Maybe the transmitter is over-modulated.
  7. #7
    Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent
    Join Date
    Mar 2007
    Location
    Hercules, California
    Posts
    1,420
    I read the OP as keying the transmitter on and off with a square wave, and of course the receiver will not demodulate such a signal.
    Lefty
    Measurement changes behavior
  8. #8
    RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent RadioRon Excellent
    Join Date
    Oct 2005
    Location
    BC, Canada
    Posts
    1,448
    Blog Entries
    1
    Well, I take it that he is feeding a baseband square wave into the transmitter's FM modulation input. As AG said, the distortion you get is dependent on several things. The transmitter audio frequency response is the first thing. For square waves of a certain frequency, say like 1000 Hz, you need good low end response down to, oh, maybe about 20Hz or so to keep the tops of the squares flat and not drooping. Also, to keep the edges reasonably straight up and down, you need very good high frequency response. For a 1000 Hz square wave, you would want flat audio response up to more than 20 KHz.
    Now, the next problem is that of the bandwidth of your receiver. FM receivers like the one you are using have IF filters that limit your frequency response of the receiver. The wider you modulate your transmitter, the more likely your receiver's IF filters will distort the audio that gets through. So you have to actually adjust your transmitter modulation to as low a level as is practical to minimize distortion of your square wave. Even so, the receiver's IF isn't wide enough to give you much bandwidth, so you are very limited to low frequency square waves, like up to maybe 2 or 3 KHz.
    RadioRon
  9. #9
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,871
    Maybe the "ready-made" FM receiver is the junk sold at The Dollar Store. Everything comes out distorted.
  10. #10
    Join Date
    Dec 2007
    Posts
    29
    hey all,thank you very much for replying my Question,but some of the replies sounds kind of derision why people ???
    My question is : Iam sending a square wave of frequency 1KHz to modulate a carrier of 96MHz,then I receive the modulated signal by a ready made receiver of a band 88 - 108 MHz and I tune it on 96MHz so I have to get the sent square wave as I sent it,,but I receive it a distorted square wave,,so what did I wrong ??
  11. #11
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,871
    Quote Originally Posted by ☼☺☼coool☼☺☼
    We told you already. Maybe the level of your square-wave signal into the transmitter is too high then the transmitter is over-modulated. Then the radio will also be over-modulated and will have severe distortion.
    We asked for you to post an oscilloscope pic of the distortion. You have not even described the distortion.
    Also, please post the schematic of your FM transmitter for us to see if it has pre-emphasis that matches the de-emphasis in the FM radio.
  12. #12
    Join Date
    Dec 2007
    Posts
    29
    thanks for reply,,,Iam gonna send you what you asked me to in the comming days I hope you to wait for me....thanks
+ Reply to Thread
  1. JDM programmer problem
    By krvavizmaj in forum Micro Controllers
    Latest: 6th August 2009, 12:24 AM
  2. please help me for solve this problem
    By Nasimrawat in forum General Electronics Chat
    Latest: 19th October 2007, 02:53 AM
  3. Pls help to solve this Pspice Schematic problem...
    By student2005 in forum General Electronics Chat
    Latest: 3rd October 2005, 02:16 PM
  4. Mysterious Problem!
    By matasoft in forum Micro Controllers
    Latest: 11th September 2004, 07:50 PM
  5. Big thermocouple ADC problem
    By Oznog in forum General Electronics Chat
    Latest: 4th May 2004, 08:42 PM
Tags for this Thread
