Old 21st January 2008, 11:21 PM   (permalink)
Hi, Hafi2_07 here is the circuit, I tried to upload last night but my ISP had problems.
The cct is built and tested. it counts up and down from 00-99 backwards or forwards. It keeps the count or you can keep counting while FL is displayed.
It resets to 00 if you wish. I had to use 4029's as I could not get 4510's.
i used a 555ic to develop a pulse for counting as the switch was very noisy and cused extra pulse to be counted. r 555/2 and c555/1 can be altered if your switch is extra noisy. I selected these values to give a fast reliable count. If you really are counting very fast then yo can probably lower these values. C switch delay 22UF is to allow the display to blank before displaying FL.
More experienced persons will probably find more elegant ways to do some things, but this circuit works well as it is. I have built and tested it.
Enjoy, btw what will you use it for and what does FL stand for.
As I said before the cct is reasonably simple but the construction is a "bitch".(About 140 solder joints)
Cheers RH
RetiredHAL is offline
Old 3rd March 2008, 03:45 PM   (permalink)
tnx for the great effort
what other ICs cn i use??
is it ok to use ne555n?74ls192? because the availability of these IC in my place is rare
motherhugger is offline
Old 3rd March 2008, 05:50 PM   (permalink)
thanx retiredHAL....i think u r really smart in electronics...
i'll try this circuit and then will inform u later....
thanx very much
hafi2_07 is offline
Old 16th March 2008, 10:24 AM   (permalink)
to...retiredhal
-- can you help me on the crct of 74ls192
--my problem is to design crct 00-99 up down counter.....
dican is offline
Old 17th March 2008, 11:25 AM   (permalink)
Originally Posted by dican
to...retiredhal
Dican, sorry, I have never used a 74lsxxxx IC so I would be giving you the wrong info. However, apart from the voltages there should be no problems using 74Ics as they are basically the same (I believe). The cct using 4XXX ICs works. Substitute the equivalent 74xxxx IC (look at the data sheets) and you should be able to construct the same. OR use the the cct I supplied --- it works!!
NB, I had never used an 4000 IC before this project (up/down counter) so I learned using the data sheets. It really is not so difficult and there are any number of 555 IC tutorials to help you to "debounce" the switch.(stop it from counting noise pulses) and give the wrong count. (I used this project as a learning experience for my next project) I learned a lot. Give it a go yourself.
Cheers RH
Old 1st April 2008, 03:56 PM   (permalink)
Unhappy ir tranceiver
hi...i need some explanation from u guys....i have attached the figure...i want to know how this circuits is working
p/s: sorry to reply at this thread...want to open new one...but i cannot open....
hafi2_07 is offline
Old 15th September 2008, 11:25 PM   (permalink)
is it possible for this circuit to count up and count down depending on a varying frequency.. like when frequency increases the count increases n when it decreases the count decreases???
hutas832 is offline
Counter circuit pas_cktmaker Electronic Projects Design/Ideas/Reviews 5 3rd October 2007 04:10 PM
Dual counter bananasiong Micro Controllers 45 24th March 2007 03:49 AM
how to build a 3digit up/down counter w/ separate inputs? poi Electronic Projects Design/Ideas/Reviews 13 12th December 2005 09:38 PM
Counter circuit refuse to count- HELP! folarinv Electronic Projects Design/Ideas/Reviews 17 24th June 2005 01:02 PM
HELP!!!!...counter circuit dorai007 General Electronics Chat 3 14th September 2004 07:38 PM
