Old 15th December 2007, 06:18 PM   (permalink)
Markley02 is on a distinguished road
Default How to turn 0-5 volts to 5-0 volts
I have a sensor that puts out 0-5 volts. When it is putting out 5 volts though, I need 0 volts. When it is putting out 0 volts I need 5 volts. When it is putting out 4 volts I need 2 volt.
How many volts I have : How many I need
0 : 5
1 : 4
2 : 3
3 : 2
4 : 1
5 : 0
I think you guys get the point. How can I do this?
Markley02 is offline   Reply With Quote
Old 15th December 2007, 06:39 PM   (permalink)
Experienced Member
ericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud ofericgibbs has much to be proud of
0 : 5
1 : 4
2 : 3
3 : 2
4 : 1
5 : 0
This circuit will get the job done.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
Old 15th December 2007, 08:41 PM   (permalink)
Experienced Member
Roff is a splendid one to beholdRoff is a splendid one to beholdRoff is a splendid one to beholdRoff is a splendid one to beholdRoff is a splendid one to beholdRoff is a splendid one to beholdRoff is a splendid one to beholdRoff is a splendid one to behold
Eric, maybe the supply voltage should be 7V or more. The LM358 datasheet says VOH is Vcc-1.5, and the part does have a Darlington emitter follower for the pullup stage. I don't have any hands-on experience with these parts, but I believe it's a good idea to go with the datasheet.
Ron
Roff is online now   Reply With Quote
Old 16th December 2007, 09:01 AM   (permalink)
Experienced Member
hi Ron,
On my earlier drawings of this circuit I used to state +8V as a supply voltage, to give that 'overhead' for +5V out.
However from the results/tests I find that the +6V will just allow a +5V limit or close to.
Also by using about +6V, the user cannot overdrive the PIC's ADCinp from a low impedance source.
Some of the earlier OPs stated they hadnt got the +8/+9v available on their projects, so I checked it out for +6V...
personally I would choose a +9V supply, as you say, these devices do vary.
Thanks for the feedback..[ if you will pardon the pun!.. ]
EDIT: the other reason for this choice of LM358, is it accepts input voltages down to 0Vin
Eric
PIC tutorials:
Old 16th December 2007, 03:12 PM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
The circuit is inverting so the input of the opamp never goes anywhere near ground.
The LM358 was chosen because its output can go down to near ground, and a load resistor will drive it closer to ground.
Its class-A pullup current is 50uA so its minimum output voltage is +0.05V with a 1k load resistor to ground.
Old 16th December 2007, 05:07 PM   (permalink)
You guys are so awesome! I cannot thank everyone enough. It actually should only need to go down to about +0.3V anyway so the +0.05V will give some room to spare.
So, I should still try +6V for the supply voltage first right?
Old 16th December 2007, 05:16 PM   (permalink)
Experienced Member
If you already have a 5V supply, you can use an op amp with rail-to-rail output and get within 50mV or less to +5V and GND if your op amp output is lightly loaded. However, you probably won't find one at Radio Schlock.
Ron
Old 16th December 2007, 05:21 PM   (permalink)
Experienced Member
The datasheet for the LM358 shows its typical output high voltage with a very low load current is about 1.2V less than its supply voltage. So with a 6V supply its max output could be +4.8V or a little more or a little less.
Old 17th December 2007, 01:14 AM   (permalink)
Experienced Member
dipmicro is on a distinguished road
How about reverting the sensor and connecting it to the 5V instead of common. No circuitry required.
www.dipmicro.com
dipmicro is offline   Reply With Quote
Old 17th December 2007, 02:34 AM   (permalink)
Experienced Member
john1 is a jewel in the roughjohn1 is a jewel in the rough
just what i was thinking.
Cross it over.
Still, some sensors have a common connection on the casing,
but i'm sure it could be done easily
if we could see the circuit.
John
john1 is offline   Reply With Quote
Old 17th December 2007, 08:31 AM   (permalink)
Experienced Member
hi Markley,
If the sensor cannot be reversed, consider using a Texas OP365, rail to rail opa with a +5V supply rail, thats if you really need the end limits of the 0/+5V.
Price wise, the OP365 in the UK is about £2GBP compared to a LM358 about £0.5GBP.
If you have +9V on the project board, power the LM358 with that.
Eric
PIC tutorials:
Old 17th December 2007, 03:08 PM   (permalink)
http://dutch.northwestmr2.com/Toyota...Inspection.pdf
That is the sensor's circuit.
Old 17th December 2007, 03:32 PM   (permalink)
Experienced Member
Looked thru your pdf.
It looks as though its not possible to switch the sensor 'over'.
Where did you get the values of 0V and +5V out from the sensor bridge, did you measure it? or was it from a datasheet?.
As it appears to be a bridge sensor, I would expect a mid range voltage on the output?
Eric
PIC tutorials:
Old 17th December 2007, 04:05 PM   (permalink)
It has a 12 volt supply. From many sources on the web it says 0V to +5V. It is possible that it could go up to +6V. If I get close to maxing it out anyway I will just increase the diameter of the pipe and that will cause a lower reading.
Old 17th December 2007, 05:31 PM   (permalink)
Experienced Member
In that case do as I suggested in my 09:13 post of today.
That is, a OP365 with a +5V supply or the LM358 with a +8V supply, using the pdf circuit I posted previously.
Does that help?
Eric
PIC tutorials:
Line Detection Robot using PIC16F877 helmyshahryl Micro Controllers 0 28th August 2007 01:53 AM
Reduce 5 volts to 3 volts, suggestions? prprog Electronic Projects Design/Ideas/Reviews 19 21st December 2006 06:02 PM
12 volts from two 9 volt batteries sandmantoy Electronic Projects Design/Ideas/Reviews 9 22nd April 2006 01:02 PM
Turn on and off air valves thup Electronic Projects Design/Ideas/Reviews 16 27th December 2003 03:19 AM
brake light/ turn signal andrew8485 Electronic Projects Design/Ideas/Reviews 13 11th November 2003 12:48 AM
