| drawing recieved I am in a part of the world where internet is not that quick thank you very much for your help Robert-Jan | |
| what i try to achieve is that i also have a 0V to 10V range at the output of the circuit i thought that that could be done by adjusting the ref V and /or the gain factor in the first posted circuit Robert-Jan | |
In that case use +12V to power the LM358 in the 1st circuit diagram and change the Vref from +2.5V to +5V. This will give for a 0v to +10v input, a +10v to 0v output. OK.?
| Is there a member of the month/year award on this site? If so, I nominate Eric. | |
| New diagram still says 5-0v output...I assume that just didn't get changed? It is actually 10-0v correct? | |
Remember: for a +10V thru 0V output, the LM358 will require a supply voltage of +12V. The Vref will have to be changed from +2.5V to +5V. OK?
| Eric thank you verry much for your help Robert-Jan | |
| Line Detection Robot using PIC16F877 | helmyshahryl | Micro Controllers | 0 | 28th August 2007 02:54 AM |
| Reduce 5 volts to 3 volts, suggestions? | prprog | Electronic Projects Design/Ideas/Reviews | 19 | 21st December 2006 07:02 PM |
| 12 volts from two 9 volt batteries | sandmantoy | Electronic Projects Design/Ideas/Reviews | 9 | 22nd April 2006 02:02 PM |
| Turn on and off air valves | thup | Electronic Projects Design/Ideas/Reviews | 16 | 27th December 2003 04:19 AM |
| brake light/ turn signal | andrew8485 | Electronic Projects Design/Ideas/Reviews | 13 | 11th November 2003 01:49 AM |
