| I have a cheap MP3 player that runs on 1 AA cell. I'd like to power it off a wall wort 3 volt AC to DC converter I have. I'd also like to have a battery in the circuit so that if house power is lost, the player will continue uninterrupted off the battery. The player is going to provide background music and music on hold through a small telephone system. The problem with just running off a converter is that after any type of power interruption, the "play" button on the MP3 player has to be pressed to get it working again. The circuit should be designed in such a way as to keep the battery charged and power the player off the converter except when the power goes off. Any ideas? | |
Of course you have to: 1) Convert the AC voltage to DC, 2) Fuse it, and 3) Regulate it to 1.5V Last edited by iONic; 14th December 2007 at 01:21 AM. | ||
| What would the circuit look like to do this? | |
| While Mr. ionic is conjuring up the circuit from his wonderful idea, perhaps you can also consider my not so clever idea of using a simple LM317 adjustable voltage regulator. The LM317 is a cheap three pin device working with a wide range of input voltages and allow the user to adjust its output voltage from 1.25V upwards, using two resistors or one fixed resistor plus one variable resistor. You don't need to use a rechargeable battery but a normal 1.5V AA battery instead. The output of the LM317 should be going to the battery (+) terminal via a series 1N4001 diode to prevent the battery discharging through the voltage setting resistors should the AC power gone off. You just need to set the LM317 voltage regulator output voltage to 2.1V(1.5V+diode 0.6V) and the AA battery will not charge or discharge under this condition and the MP3 will work happily at 1.5V. The input to the LM317 should be about 5V or more via a common AC/DC wall adaptor. More information is available by googling "LM317".
__________________ L.Chung | |
| why not just plug the mp3 player's wart into the same ups that powers the phone system?
__________________ If you don't have a planet, what good are gold bars? want to contact me directly? gmail gordonthree check out my project website: http://projects.dimension-x.net Favorite numbers: 09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0 | |
P.S. It may need some tweaking though... Last edited by iONic; 14th December 2007 at 06:57 PM. | ||
The current from a phone line is much too low to power an MP3 player. The pot connected to the LM317 does not adjust its voltage. Pin 2 is grounded so the output voltage is fixed at 1.25V but will rise to about 1.5V without a load.
| iONic, Your circuit has a lot of problems. 1. The absolute maximum input-output differential voltage for the LM317 is 40Vdc. The ON-hook line voltage is nominally 48Vdc. Ring voltage is around 96Vac 2. Phone lines are not intended to be power supplies for other devices, so attaching you bridge directly across the line and supplying the needed current for the MP3 player will load down the line. As the current increases the line voltage drops...probably to the point of creating an Off-hook condition. Phone companies don't like this. If I recall correctly, the maximum current available in an Off-hook condition is about 20mA. 3. Your variable resistor from pin 3 to pin 2 will only work if there is a fixed resistor from pin 2 to ground. And with that, Cout's negative terminal would be connected to LM317's pin 2 as opposed to ground. Ken
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) | |
Your right about the 500 ohm pot, it should be replaced with a 240 ohm fixed resistor and place the pot from pin 2 to ground. | ||
I will conceed. Last edited by iONic; 14th December 2007 at 06:57 PM. | ||
| iONic, Your imagination is great...and your pile of junk seems adequate. Ken
| Generally the phone lines feed a current limited (each limb) supply of -48V and earth.the limit is around 35mA, but as the line loop resistance increases (for the far off phones) the current would less. added to that, the lines don't care about 3 to 4 mA of leakage current in the modern exchanges. It amounts to misuse of telephone line to tap and connect devices across the phone lines, and certain telecom companies can even object to it. I wonder that the whole thing is around externally powering an MP3 player device that would comfortably work from a AAA cell.
| Modern telephone exchanges time-out and disconnect a phone line that is off-hook for a couple of minutes.
....Yikes, then I had better unplug my TV!! | ||
| Led cyclic dimmer/controller circuit? | yel-low | Electronic Projects Design/Ideas/Reviews | 13 | 9th August 2004 05:00 PM |
| start/stop watch circuit | bd13 | Electronic Projects Design/Ideas/Reviews | 2 | 21st March 2004 04:07 AM |
| Circuit functioning very strange. Why? | Cyclone | Electronic Projects Design/Ideas/Reviews | 12 | 4th November 2003 01:31 AM |
| Real world test measurements? | SomeoneKnows | General Electronics Chat | 8 | 26th August 2003 07:38 PM |
| Digital volt meter circuit | Power-U | Electronic Projects Design/Ideas/Reviews | 1 | 31st March 2003 12:01 PM |
