+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 22
Thread: Variable Freq Oscillator
  1. #1
    forever99482 Newbie
    Join Date
    Mar 2007
    Location
    malaysia
    Posts
    37
    Default Variable Freq Oscillator
    Hi, I've got a question about the circuit below
    As it is using a TCA440, the oscillator and mixer is actually in it, and I cannot test to see the output from the Variable Freq Oscillator(kank3333r part), any ideas of how I could test to see the output of the VFO is correct?
    By the way, can anyone find the datasheet of kank3333r?? I googled it and can't seem to find the datasheet of it.
    Thanks in advance
  2. #2
    on1aag Good on1aag Good on1aag Good
    Join Date
    Aug 2006
    Posts
    512
    Hi Forever99482,
    You can try to measure at pin 5 of the TCA440.
    Data for the BKANK3333R :
    between pins 1 and 2 14 turns
    between pins 2 and 3 41 turns
    between pins 1 and 3 55 turns
    between pins 4 and 6 14 turns, pin 5 is not connected !
    Inductance 45 µH, Q = 60 probably measured between pins 1 and 3.
    on1aag.
  3. #3
    forever99482 Newbie
    Join Date
    Mar 2007
    Location
    malaysia
    Posts
    37
    Quote Originally Posted by on1aag
    on1aag.
    pin 5(toko) is not connected?? but the circuit shows that it is connected to pin 5 of tca440. Please explain a bit more, I might be confused.
    some more questions,
    1. what frequency should I be looking at before the input to the lm386 (pin 3)?
    2. What frequency should I be expecting on the mixer output of tca440, as I'm seeing frequency as high as 100MHz.....
    Thank you
  4. #4
    Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent
    Join Date
    Mar 2007
    Location
    Hercules, California
    Posts
    1,420
    Quote Originally Posted by forever99482
    Thank you
    1. Audio frequencies only, as this is after the signal has been detected and filtered by the detector diodes, for AM audio modulation content only.
    2. 455khz that then feeds to the ceramic IF 455khz filter to remove any other mixer products.
    Your local osillator will have to cover a 3.045 to 3.545mhz range to convert the 3.5-4mhz ham 80 meter band to the 455khz IF frequency of this design.
    Lefty
    Measurement changes behavior
  5. #5
    forever99482 Newbie
    Join Date
    Mar 2007
    Location
    malaysia
    Posts
    37
    As I'm not inputing any RF signals to it, so shouldn't the mixer output be around 3.5MHz? Unless my VFO is not working correctly....
  6. #6
    Join Date
    Mar 2007
    Location
    Posts
    1,420
    Most mixer designs use a balanced mixer that only outputs the sum or difference between RF and LO. If no RF or no LO then there would be no mixer output at all. You can normally not troubleshoot mixer problems easily without a spectrum analyzer.
    Lefty
  7. #7
    Join Date
    Aug 2006
    Posts
    512
    Hi Forever99482,
    The pin 5 mystery is only a typo that probably sneeked in because
    pin 6 of the KANK3333R is connected to pin 5 of the TCA440.
    As with most Toko 10K coils pin 5 is missing, so it can't be connected
    to pin 5 ! The general rule is if it isn't necessary pin 5 is always
    missing, the same goes for KANK3334R, KANK3335R and a lot of other
    Toko coils.
    on1aag.
  8. #8
    forever99482 Newbie
    Join Date
    Mar 2007
    Location
    malaysia
    Posts
    37
    about the trimmer cap in the VFO part, is it used for impedance matching with the toko?
    What frequency should I be looking at for pin4,5 and 6 of TCA440 with an AM modulated sinewave of 3.5MHz fed in to pin1/2 of the TCA440
  9. #9
    Join Date
    Aug 2006
    Posts
    512
    Hi Forever99482,
    The trimmer cap C11 is used to set the frequency of the local oscillator
    that it will cover the 80 m band.
    It has nothing to do with impedance matching.
    The signal measured at pins 4,5 and 6 will always be the oscillator
    frequency no matter what signal you apply to the inputs of the TCA440.
    I've checked the internal circuitry of the TCA440 and pins 4 and 5 are
    differential inputs, pin 6 is the open collector output of the oscillator.
    Try to measure the signal at pin 6 of the TCA440.
    Make sure you haven't mixed up the connections of the KANK3333R,
    I measure 0,7 hm: between pins 1 and 2
    and 1,9 hm: between pins 2 and 3 which seems to agree with
    the schematic.
    The Toko catalogue doesn't give a specific footprint for the KANK3333R
    but from what I can measure I think that the pins are numbered like
    integrated circuits.
    on1aag.
  10. #10
    electrocompo Newbie
    Join Date
    Dec 2007
    Posts
    5
    Default tca440 oscillator
    Hello,
    Can anybody please help me out with oscillator configuration of the tca440.
    the internal oscillator circuit can be controlled by pin 4 5 and 6. my questions are
    1) how do you control the frequency of the signal produced by this internal oscillator by using this three pins?
    2) am i suppose to build a whole new oscillator circuit to control the internal one?
    3) how do i build an oscillator circuit that controls another oscillator circuit?
    Thanking you i advance
  11. #11
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,775
    Quote Originally Posted by electrocompo
    Hello,
    You use a tuned circuit to set the frequency, like almost every RF oscillator there is - it's clearly shown on the diagram above.
  12. #12
    electrocompo Newbie
    Join Date
    Dec 2007
    Posts
    5
    Thanks for the reply!
    the oscillator circuit above is just too confusing (I'm kind of new to this.. ).
    So there are many kinds of RF oscillator that I can use with the tca440?
    Arent RF oscillator meant to be connected to the mixer directly... I mean if it is an RF oscillator and we are connecting it to another oscillator (the internal one) then its like two oscillator connected together? does that make sense?
    I really need help with this topic
  13. #13
    Join Date
    Aug 2006
    Posts
    512
    Hi Electrocompo,
    The TCA440 is a single chip single conversion AM receiver.
    All active components are inside the chip and the oscillator
    is allready connected to the mixer. Only the frequency dependant
    components are external.
    http://www.alldatasheet.com/view.jsp?Searchword=TCA440
    on1aag.
  14. #14
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,775
    Like on1aag says, there's only one oscillator circuit there, with the active part inside the chip, and the LC tuning part outside the chip - two halves make a whole.
    You're making it far more complicated than it is!.
  15. #15
    mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent mvs sarma Excellent
    Join Date
    Oct 2006
    Location
    Hyderabad, India.
    Posts
    2,475
    Blog Entries
    1
    Thank you
    Hi Forever99482,
    where did you get the TCA440 in Malaysia and at what price-- as I need few pieces for a friend in Malaysia. plse try to give shot contact if you had purchase recently sir
    Regards,
    Sarma.
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. photodiode used for IR variable freq monitor?
    By jaydag71 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 8th July 2007, 05:16 AM
  2. High Frequency Variable Oscillator
    By nos_slived in forum Electronic Projects Design/Ideas/Reviews
    Latest: 2nd April 2005, 05:16 AM
  3. 555-based variable frequency square-wave oscillator
    By indecided in forum Electronic Projects Design/Ideas/Reviews
    Latest: 28th January 2005, 05:57 AM
  4. PIC-to-LCD interface, Powersupply, Oscillator freq.
    By egh01 in forum Micro Controllers
    Latest: 16th September 2003, 12:21 AM
  5. Help on variable oscillator
    By Curt in forum General Electronics Chat
    Latest: 3rd September 2003, 02:03 PM
Tags for this Thread
